Trying to set up VKING Yt it's a 2003
Junior stanley
Post: # 22278Post Junior stanley »
Need help I have 6 inch jackplate 15 inch mid Bob's lwp 1/4 below running a 245 HP carburetor motor only running around ,84 mph I was told I need 10 inch jackplate
Re: Trying to set up VKING Yt it's a 2003
Post: # 22280Post Hippie459MN »
10 inch plate is way to much for a vking and with that 15" mid you could probably get away with a 4" plate.
If it was a vulture or a Vegas I could see a 10" plate for sure but way overkill for a vking.
Also, start with the prop shaft even with the pad seeing that you have a lwp and adjust from there. I know a few guys that end up an inch above the pad.
Junior stanley
Post: # 22282Post Junior stanley »
I have been 1/2 above no lift almost ride nose down running a 26 chopper I have trying a few different props now
Junior stanley
Post: # 22283Post Junior stanley »
Thanks for the info I will try anything at this point lol
Post: # 22284Post Hippie459MN »
You have a picture of the boat and set up? Where is the battery, gas tank, etc...
Junior stanley
Post: # 22285Post Junior stanley »
Junior stanley
Post: # 22286Post Junior stanley »
No pictures of set up I have lower unit off getting work done I have pics
Post: # 22287Post Hippie459MN »
Where is your battery and fuel tank in the boat?
Post: # 22288Post Hippie459MN »
Maybe you just need to trim it up more.
Junior stanley
Post: # 22289Post Junior stanley »
I have to the 🌒 lol
