Trying to set up VKING Yt it's a 2003
Need help I have 6 inch jackplate 15 inch mid Bob's lwp 1/4 below running a 245 HP carburetor motor only running around ,84 mph I was told I need 10 inch jackplate
- Has thanked: 358 times
- Been thanked: 83 times
Re: Trying to set up VKING Yt it's a 2003
10 inch plate is way to much for a vking and with that 15" mid you could probably get away with a 4" plate.
If it was a vulture or a Vegas I could see a 10" plate for sure but way overkill for a vking.
Also, start with the prop shaft even with the pad seeing that you have a lwp and adjust from there. I know a few guys that end up an inch above the pad.
I have been 1/2 above no lift almost ride nose down running a 26 chopper I have trying a few different props now
Thanks for the info I will try anything at this point lol
You have a picture of the boat and set up? Where is the battery, gas tank, etc...
No pictures of set up I have lower unit off getting work done I have pics
Where is your battery and fuel tank in the boat?
Maybe you just need to trim it up more.
- 39Replies
- 282352 Views
Jan 06, 2023 1:17 pm
- 78526 Views
Sep 22, 2021 8:27 pm
- 62357 Views
Nov 22, 2021 5:08 pm
- 68707 Views
Oct 10, 2021 9:14 am
- 60432 Views
Oct 29, 2021 9:24 am
