1980 Viper Rebirth
Re: 1980 Viper Rebirth
Wow sorry. I guess i forgot to add more. The wife and I were living in her grandfather's house after he passed - it was sold so we were scrambling to find a new place to live (i.e. get approved for a mortgage and buy our own). I'll have to find my camera and get those pics loaded.
Alright, found my camera.
This work was done periodically between June 6th and roughly middle of July 2018. I was super busy with trying to find and buy a house, and packing up all my stuff.
Dealing with the gap between the transom skin and the new transom, I ended up using a prybar to gently widen the gap a few millimeters to allow resin to get down a bit deeper, and then clamped the hell out of it.
Now onto the (not so) fun stuff. Balsa core.
I should note that for this stage of my work, I'm using general purpose ortho polyester resin. I heard Vinylester doesn't play well with CoreBond under vacuum, so I went with poly.
Unfortunately with the house bullsh*t, my new glass had long since cured. So I knew id have to re-grind. Just a light job to create a mechanical bond. I started in the pad, scuffing the main surface while straightening the edges to fit the core.
Next I laid down a layer of CSM, and let that tack up while I prepped the bagging stuff, CoreBond and primed my balsa.
Due to the nature of the work as some of you know, I didn't have time to photograph each step in the process. It was warm this day and my resin was starting to gel around 20 minutes.
After I laid down the CSM, I encompassed the area with sealant tape. I went back to my work table and mixed up my resin for balsa priming, and smothered the balsa. Then prepped the CoreBond and troweled that into the pad. On went the balsa. Then went on the peel-ply. Then 2 layers of paper towel, then the bag. I'm actually using run-of-the-mill plastic vapor barrier you can buy at Home Depot, etc. Much much cheaper than bagging film, and works just the same, if not better. I found that bagging film was much stiffer - similar to cellophane than flexible plastic.
Not a perfect vacuum, but this still created several hundred pounds of "weight".
Let's see the result.
Shiny!
Continued working up the pad...
Second piece of core was a bit higher - I'll sand this down later...
Then started on the port side. Light grind, sweep&vacuum, followed by layer of wetted-out CSM.
Unfortunately, this is all I got done before moving. Everything got packed up, and is still packed up. With having a new house, I never had time the rest of the summer and fall to work on her.
So she's sleeping in the backyard under her boat cover and heavy-duty tarp.
Hopefully winter will be short.
Until then.....
Shiny!
Until then.....
- Has thanked: 351 times
Looks awesome.
Well at least now I can work in any weather....
Time to build a new cradle like I had at my cousin's farm 3 years ago.
- KIMG0303.jpg (1.88 MiB) Viewed 7229 times
- KIMG0302.jpg (2.7 MiB) Viewed 7229 times
Awesome! Cant wait to see you back at it.
Built a "light" for my shelter. Powered by five 9-watt LED bulbs @ 800 lumens each. 4000 lumens total.
Finished the cradle. Didn't see a point in adding more supports under the bow as this isn't a weight-bearing area....i.e. i wont be stepping/standing there.
Next is to break out the sander & grinder and clean up the mess of corebond around the transom and balsa, and get back to prepping the glass for more balsa vacuum-bagging.
Deck Underside Deconstruction - Part 1
I haven't had a chance to buy more 1.5oz CSM, so I haven't been able to continue bagging the core in the hull.
I decided in the meantime to work on the underside of the deck.
The wood structure in it is in pretty bad shape, so tearing it all out and replacing it is the only logical option.
Started grinding with a 40-grit flap disc, but switched it back to my 36-grit brazed cup wheel.
Ah, you know what? Lemme deal with this weird thing in the middle instead.
At this point, I just started alternating between grinding, and whatever this green shite is. I still don't know what you'd call it.
It has the same texture, and crumbles very easily, like a 30-year old pool noodle.
Cut off the triangular lateral brace - inside was this soft foam, like you'd find in a cheap seat cushion...
Dash removal begins...
Removal of the flimsy 1/4" plywood...
My goal this weekend is to have the entire underside of the deck stripped of wood, and ground/prepped for 1708.
- Been thanked: 12 times
Adam, something to consider while you have your deck at this stage. I added these "looms" using a cut up cardboard roll. While rigging the hull, as was very glad that I added them. great place to keep all the cables and wires contained. Your project is looking awesome!!
Thanks Joe. Yours and Ron Pratts rebuilds are huge influencers in my build.
I actually bought a few packages of various sized rigid plastic "C" straps - the ones used for electrical conduits. Gonna 5200 those on when the underside is rebuilt.
- 37675058_L.jpg (60.41 KiB) Viewed 7034 times
- 138183 Views
Jan 29, 2021 9:17 pm
- 114304 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 192948 Views
Jun 03, 2021 11:12 pm
- 52326 Views
Feb 17, 2021 9:22 am
- 42814 Views
Mar 01, 2021 6:53 pm
