Bobs nose cone
bottomofdaboot69
Been thanked: 4 times
Bobs nose cone
Post: # 22986Post bottomofdaboot69 »
Im looking to see you guys opinion on whats the best epoxy/ metal to metal bond to use on a bobs cone for lower unit.
86 Vking YT
84 Vking
8? vector comp
74 Checkmate vmate
Re: Bobs nose cone
Post: # 22988Post Hippie459MN »
A lot of guys use duraglass for the body work. Just prep the metal good so the duraglass gets a good bite. I haven't personally done one so I can't say but that's what I have been told when I asked about having to repair mine.
nosboss
Re: Bobs nose cone
Post: # 22991Post nosboss »
I did four small stitch welds and filled the cavity with the epoxy Bobs sends with it. I then used short strand reinforced filler to fill the sides and finish it out. Have done a few this way with no failures.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
bruzercomp81
Been thanked: 3 times
Re: Bobs nose cone
Post: # 22993Post bruzercomp81 »
I did exactly what nosboss did. Hasn't cracked at all
bottomofdaboot69
Re: Bobs nose cone
Post: # 22999Post bottomofdaboot69 »
thanks fellas i already have a cone on it from when i bought it but it has a big chunk missing out of the side.
86 Vking YT
84 Vking
8? vector comp
74 Checkmate vmate
AndrewZ
Been thanked: 7 times
Re: Bobs nose cone
Post: # 23033Post AndrewZ »
3m panelbond
