1984 hydrostream vector tearing down
Re: 1984 hydrostream vector tearing down
I seen something about a hook in pad should this boat have a hook in the pad??
hook......wedge.....whatever its called.......YES
put a 6' level on pad......you should see light about 24-36" from end of pad
Ok cause I can look down it at bottom from back and see in just eyeballing it I'm guessing I would see 1/4 inch of daylight
Another question when I start taking all the core out, the boat is sitting on that trailer well how much more support does it need to hold it's right shape will it warp up or will the boat pretty much hold it's self
Should be supported as well as you possibly can. Best looking jig I ever saw on this threadcottontop58 wrote:Another question when I start taking all the core out, the boat is sitting on that trailer well how much more support does it need to hold it's right shape will it warp up or will the boat pretty much hold it's self
http://www.hydrostreamforums.com/viewtopic.php?f=13&t=2090&hilit=viper+jig
havent did much work on the boat but got out there and just cut on it a little more, havent built a jig or put anymore supports on my trailer, so i havent cut much, and trying to be carefull cause kinda confused where the core balsa stops and starts here is a picture of where i think i opened up the pad box and dug into the pad, the is the bottom skin there right?
- pad box.jpg (618.41 KiB) Viewed 6408 times
- Been thanked: 7 times
You're doing a great job so far, keep on going carefully and you should do just fine! looks like you found the core area in the pad too. Keep it up
Just curious but once I do get to the point of laying core , is there something better than balsa and other question is one the balsa is layed would it be better to get it shot over with a chopper gun I know someone who builds boats that's could do it , just wanting the best sealed off way when I get to that point
From what I have been reading, balsa is a great core for a boat. I would say make sure you soak some resin in the balsa before you lay it in the hull, and make sure there is enough resin to make a bond if it soaks up a little more. on top, I did mine with a layer of 17 oz and used a paint brush to spread out the resin for the most part. then rolled it out with a glass roller. Once I get more stuff its on to the stringers. If you are worried about it being sealed up, make sure you are using enough resin. the top side will definitely soak it up. Gel coat will help seal it up better also when you go to finish it up
- 226214 Views
- 163267 Views
- 197792 Views
- 167407 Views
- 106342 Views
- Last post by msethsmile+
Dec 12, 2018 10:24 am
