1976 Hydrostream Vector
- Has thanked: 2 times
- Been thanked: 4 times
Picked up this vector last February. More pics and progress to follow.
- The day I picked it up
- IMG_6833.jpeg (726.22 KiB) Viewed 7245 times
Re: 1976 Hydrostream Vector
Here’s some pictures of the tear down, unfortunately someone did some “repairs” so the port side required a lot more grinding. Yes. That is about 2 inches of resin someone poured there. Also pictured are the patches the previous owner put on.
- IMG_7129.jpeg (623.05 KiB) Viewed 7242 times
- IMG_6865.jpeg (862.54 KiB) Viewed 7242 times
- IMG_6863.jpeg (856.02 KiB) Viewed 7242 times
- IMG_6851.jpeg (602.77 KiB) Viewed 7242 times
- IMG_6850.jpeg (963.63 KiB) Viewed 7242 times
- IMG_6849.jpeg (920.2 KiB) Viewed 7242 times
- IMG_6848.jpeg (687.75 KiB) Viewed 7242 times
- IMG_6847.jpeg (643.07 KiB) Viewed 7242 times
- IMG_6846.jpeg (516.15 KiB) Viewed 7242 times
- IMG_6845.jpeg (566.99 KiB) Viewed 7242 times
- IMG_6844.jpeg (471.86 KiB) Viewed 7242 times
- IMG_6843.jpeg (732.96 KiB) Viewed 7242 times
- IMG_6842.jpeg (569.96 KiB) Viewed 7242 times
- IMG_6841.jpeg (883.29 KiB) Viewed 7242 times
Here I start cutting out the transom. I decided to do away with the splashwell so I can run bigger transom knees and carry more fuel.
- IMG_7328.jpeg (485.25 KiB) Viewed 7212 times
- 70596871205__12F3A4EC-F060-4312-AEDC-03A59077567B.jpeg (634.28 KiB) Viewed 7212 times
- Its definitely had a few different motors over the years.
- IMG_7187.jpeg (577.39 KiB) Viewed 7212 times
All of the balsa and old glass ground out. Since this is a early vector 2 the build quality is very poor so I decided to leave the bow support and front core (whats left of it) intact until I get some structure back into the boat.
- IMG_8057.jpeg (463.8 KiB) Viewed 7212 times
The first round of patching done with 1708. More glass will be added later to tie all of the smaller patches together. Since this boat is already so thin from previous repairs on the port side (down to the gelcoat in some spots) an extra layer of glass will not hurt.
- Yes those ugly spots were also fixed I just forgot to get a picture.
- IMG_8564.jpeg (510.04 KiB) Viewed 7212 times
- IMG_8563.jpeg (438.06 KiB) Viewed 7212 times
Couple pictures of the transom going in. I used two sheets of 3/4 marine ply to get the stock 1.5 inch thickness. They were stuck together with resin rich 1.5oz csm mat. The outer skin of the boat was really out of shape from the years of motors pulling on it so I clamped the transom core to the outside to hold it straight while the layer of mat dried on the inside. I bonded the ply to the skin with Bond A Lite (my local fiberglass suppliers version of core bond). For tabbing I used 5 layers of 1708 starting at 4" wide stepping up 2" with each layer on the sides and bottom of the transom. Probably overkill.
- Didn't get a great picture of finished tabbing.
- IMG_8645.jpeg (483.96 KiB) Viewed 7211 times
- IMG_8488.jpeg (337.05 KiB) Viewed 7211 times
- IMG_8451.jpeg (233.8 KiB) Viewed 7211 times
- IMG_8454.jpeg (467.14 KiB) Viewed 7211 times
- IMG_8317.jpeg (454.39 KiB) Viewed 7211 times
- IMG_8256.jpeg (345.24 KiB) Viewed 7211 times
This brings us up to current day. I covered the whole bottom in 1708. Since this is a early vector the core does not go all the way into the wings. However I am going to add glass all the way up. Next I am going to grind out a couple air bubbles on the edge and fix those. I decided to put a 8 foot 50" wide section of 1708 in the length of the boat, I DO NOT RECCOMEND doing it this way as it is very difficult to get the air out of the chines and pad corners without a lot of patience.
- IMG_8646.jpeg (364.96 KiB) Viewed 7211 times
Looking good. That's the good thing about fiberglass, it can always be fixed. Glad to see another stream being saved. Can't wait to see more.
Some more progress, bow core removed. Waiting on some shop space to clear up so I can get to glassing, winter rules out doing it outside.
- IMG_8860.jpg (265.06 KiB) Viewed 4370 times
- IMG_8824.jpg (366.86 KiB) Viewed 4370 times
Looking good! Getting that stuff outta the bod is no fun but its gotta be done.
- 39Replies
- 23382 Views
- Last post by Rut311969
Mar 08, 2012 11:49 pm
- 5150 Views
- Last post by fla.viper
Feb 23, 2012 12:30 pm
- 10654 Views
- Last post by cajunmerc
Feb 24, 2012 7:48 am
- 8824 Views
Feb 23, 2012 5:37 pm
- 7672 Views
Feb 23, 2012 5:31 pm
