Thanks! My goal for this build is a resto-mod feel. I want it to look as original as possible, but with newer gauges, better rigging, and updated interior while maintaining the original style. I want a radio in it, but it needs to be hidden. So the speakers are underneath and the head unit will be mounted to the brace below the windshield. The head unit can be completely controlled via a phone app so I don't need to see the face.Hippie459MN wrote: ↑Feb 09, 2020 4:28 pm Looking great. I love the speaker mount idea. Outta sight for sure and probably stay good and dry tucked up under there.
1978 Viking resto-mod
Re: 1978 Viking resto-mod
The boat is out of the cradle and flipped over for the bottom work. Repair all the damage, blueprint the last 6', and spray new gel with the same metal flake.
I finished glassing in the splash well before flipping the hull. Made a simple mold to form the drain in the well. Used parchment paper to cover it for a release.
The hull/deck seam was glassed on the inside with 2" CSM and 4" 1708.
- IMG_6371.JPG (2.4 MiB) Viewed 8361 times
- IMG_6375.JPG (2.32 MiB) Viewed 8361 times
- IMG_6376.JPG (2.43 MiB) Viewed 8361 times
- IMG_6381 2.JPG (2.32 MiB) Viewed 8361 times
- IMG_6382 2.JPG (2.38 MiB) Viewed 8361 times
- IMG_6384 2.JPG (2.14 MiB) Viewed 8361 times
- IMG_6390.JPG (2.14 MiB) Viewed 8361 times
- IMG_6396.jpg (2.97 MiB) Viewed 8361 times
Started in on the bottom work. Found an awful lot of stress cracks, any of those that I could catch with a finger nail I ground out and patched in with CSM. Most spots only needed one or two layers of mat. I'm now working on the blueprinting process. I have the first layer of body filler in and sanded and starting in on the remaining low spots.
- IMG_6404.JPG (2.75 MiB) Viewed 8341 times
- IMG_6419.JPG (2.36 MiB) Viewed 8341 times
- IMG_6422.JPG (2.6 MiB) Viewed 8341 times
- IMG_6423.JPG (2.27 MiB) Viewed 8341 times
- IMG_6431.JPG (2.56 MiB) Viewed 8341 times
- IMG_6434.jpg (2.34 MiB) Viewed 8341 times
- IMG_6435.JPG (2.69 MiB) Viewed 8341 times
Thats really looking great! I cant wait for it to warm up out so I can get to doing some body work on mine so I can get the jack plate and motor mounted at least.
Blueprinting has been completed! Also got the primer on.
- IMG_6472.JPG (1.9 MiB) Viewed 8323 times
- IMG_6505.JPG (1.95 MiB) Viewed 8323 times
- IMG_6520.JPG (2.18 MiB) Viewed 8323 times
- IMG_6523.JPG (1.81 MiB) Viewed 8323 times
- IMG_6524.JPG (1.7 MiB) Viewed 8323 times
- IMG_6525.JPG (1.71 MiB) Viewed 8323 times
- IMG_6526.jpg (2.57 MiB) Viewed 8323 times
- IMG_6527.jpg (2.34 MiB) Viewed 8323 times
- Been thanked: 73 times
Adding to your thread here Tony, if you'll forgive me, based on what you mentioned in the Facebook post. Just in case someone reads here instead of FB.
You used AdTech P-14 Ultra Filler:
https://www.expresscomposites.com/ad-tech-p-14-ultra-filler-white-with-white-bpo
3M Guide Coat
Duratec Vinylester Primer
https://www.expresscomposites.com/vinylester-primers
The Express Composites link above mentions 2 different Primers - regular and Fairing. Which one did you use?
3M Guide Coat
No problem at all, Adam. That is everything I used. The VE primer is the regular primer, not fairing primer.
Bottom is gel coated!
- IMG_6545.JPG (2.25 MiB) Viewed 8291 times
- IMG_6554.JPG (2.18 MiB) Viewed 8291 times
- IMG_6578.JPG (2.21 MiB) Viewed 8291 times
- IMG_6579.JPG (2.76 MiB) Viewed 8291 times
- IMG_6581.JPG (2.63 MiB) Viewed 8291 times
- IMG_6582.JPG (2.78 MiB) Viewed 8291 times
- IMG_6583.JPG (2.71 MiB) Viewed 8291 times
- IMG_6584.JPG (2.52 MiB) Viewed 8291 times
Yeah buddy! Looking awesome!
The vinylester primer...you just brushed/rolled it on?
Also, how much did you use?
- 5775 Views
- Last post by ConFuseee
May 11, 2011 5:06 pm
- 34Replies
- 17471 Views
- Last post by fla.viper
Jul 22, 2011 1:12 am
- 5771 Views
- Last post by RedDemon
May 12, 2011 7:06 am
- 5630 Views
May 12, 2011 7:59 am
- 6052 Views
- Last post by LSaupe
May 13, 2011 6:41 pm
