new member with a 78 viper
Surface Scratcher
Post: # 20633Post Surface Scratcher »
I suspect that water will be pressured out of those holes at speed. I've never seen that before. Possibly, they first closed up the upper holes and later added the cone but didn't close the remaining holes. :thinking:
Anyone else?
Post: # 20634Post Hippie459MN »
If you have a low water pickup you are going to want to plug all of the original water pick ups on the lower. Could also cause it to pull air also possibly. You could try it as is but keep a real close eye on your water pressure and temp.
aaron78viper
Been thanked: 11 times
Post: # 20635Post aaron78viper »
Will probably cover up the top holes. that will simplify using a hose at home when running the motor. Wondering about water pump kits and thermostats? where is a good place to buy? anything else I should know? Is there an easy way to rig up new controls to it?
aaron78viper
Post: # 21040Post aaron78viper »
well I got motivated, I know I know, I cant make up my mind... but im doing work...
aaron78viper
Post: # 21129Post aaron78viper »
the seat and transom
seat excitement.jpg (69.32 KiB) Viewed 21175 times
hydrostream transom.jpg (42.5 KiB) Viewed 21175 times
aaron78viper
Post: # 21130Post aaron78viper »
14 inch wood steering wheel anyone? I think so
steering wheel.jpg (45.97 KiB) Viewed 21175 times
aaron78viper
Post: # 21716Post aaron78viper »
So I've been a little busy... Haven't done all the wiring at all.. But its running! Really light and very fast for a 150.. Needs solid mounts and a jackplate.. Also need to invest in some nice gauges
Post: # 21717Post RussF »
:up:
aaron78viper
Post: # 22583Post aaron78viper »
here is a link to my rig with a 2.0 running about 85. 30 cleaver and 3 inch setback with a 2:1 case and a lwp
Post: # 22584Post Hippie459MN »
Looks like that thing is really flyin. Very nice! :up:
