Viper rebuild
- Been thanked: 12 times
Re: Viper rebuild
Started putting the inner core in. Started out with 8' over the pad. It was bedded in 1 evening and glassed in the next evening. Before I glassed it in I did Ron Pratt's quarter test and found a very small spot over the driver seat area that had a distingtively differnt tone. Drilled a 1/8" hole to the pad surface and backfilled it with resin. It didn't take much, but the different tone was gone when I rechecked it. Thank's Ron!
- DSCF4339 (Copy).JPG (112.97 KiB) Viewed 4116 times
- DSCF4341 (Copy).JPG (119.12 KiB) Viewed 4116 times
Re: Viper rebuild
Looking good, keep the pics coming
Re: Viper rebuild
Yes, it is 3/4" 7-ply douglas fir marine grade plywood. My original intention was to use Sitka spruce for it's strength and lightness. I found this marine plywood at a specialty lumber store near me for a lot less than the spruce. I think it will be plenty strong and found it to be fairly light as well.jacklake2003 wrote:You're doing very nice work! Is that marine plywood?
Re: Viper rebuild
I'm a bit confused. There appears to be an awful lot of old balsa still in place
Re: Viper rebuild
Not sure where you see old balsa? When this hull was gutted, there was not a sliver of wood, of any type, left in the hull. All wood you are currently seeing is new wood, Douglas Fir plywood and endgrain balsa.transomstand wrote:I'm a bit confused. There appears to be an awful lot of old balsa still in place
Re: Viper rebuild
Could be just the photo, but it appears there is still balsa material in place. Or it may be new already?
Re: Viper rebuild
I agree now that you point that out. That looks like its not ground out all the way. Here is what it should look like when its all cleaned up nice
This is my Vulture with all of the wood ground out of it.
Have to get it all out down to the glass and get every last piece of wood out.
Re: Viper rebuild
I understand what your looking at now. When I removed all the old core, it left some residual glue or bedding material stuck to the fiberglass. Look again at the center core section. This residual material all gets ground out and a layer of 1.5oz glass was laid down to give the new core a nice flat bed to adhere to. The area that Transomstand sketched out will get ground down as well. This is the first time i've ever done a project like this and trying to learn from many of the previous threads. I can tell you that I would have never tried to tackle this endevour if it wasn't for all the great advice and knowledge that has been made available on this site. The Hydrostream "culture" is absolutely awesome!!!
Hippie, looks like you have the tuff part done on your hull...time to get the reconstruction under way. Thanks for all the advise my friends!
Re: Viper rebuild
All of my cored is bedded and in, Just need to finish covering all of it and put the floor down then flip it over and fix the botom and then put the motor on it and hopefully have a working boat.
- 20710 Views
- Last post by Vegas XT
Jun 22, 2009 8:54 am
- 19Replies
- 42620 Views
- Last post by BUSHWACKER
Jun 26, 2009 3:21 am
- 23100 Views
Jun 27, 2009 10:02 am
- 29003 Views
Jul 09, 2009 8:09 pm
- 27187 Views
- Last post by ccrick
Jul 10, 2009 11:00 pm
