New Hydrostream guy
OMCFREAK
New Hydrostream guy
Post: # 16939Post OMCFREAK »
After wanting a Hydrostream for a long time, I finally got one. Probably not everyones favorite, but it's a 1985 Vamp with a great transom and bone dry core. Better yet it was $600 less engine with an EZ loader bunk trailer. My 74 Johnson only pushes it about 52 GPS, but only paid $300 for the engine and it runs like a champ. I'll make some mods to it to help with power. It spins a 24p original Raker.
Re: New Hydrostream guy
Post: # 16941Post Hippie459MN »
Welcome and congrats on the purchase. I would say by the looks of it you got one heck of a deal for $600.
I bet just with some set up and not touching anything with the motor, You could get much more then 52mph out of it. Im going to guess the motor is pretty deep in the water by the looks of it.
OMCFREAK
Post: # 16943Post OMCFREAK »
Yep, motor is bolted to the transom and running deep. Definitely want to get a jack plate. I will be working on the setup as long as weather permits this fall. Also will be doing a bit of engine work along the way. Can't wait to make it to a get together next year.
Post: # 16944Post Hippie459MN »
Raise up that motor and get that prop shaft as close as you can to level with the pad without loosing water pressure (Assuming you dont have nose cona with a low water pick up) and I bet your numbers will go way up! If you cant go any higher on the transom you may need a jackplate but I would bet that a 2-4 inch plate will do wonders as well.
Rut311969
Post: # 16948Post Rut311969 »
Welcome .I like the boat but as Hippie said raise the motor and it well be faster and probly handle better . I run a rude to on a Voyager another family oriented Stream and I love it .I'm just right down the Mississippi from you in Burlington .
OMCFREAK
Post: # 16949Post OMCFREAK »
Hmm....looks like it is getting sunny out......says 62 degrees for next Saturday...hope the weather man is right!
Andrew Vision
Post: # 16958Post Andrew Vision »
Welcome! I've never seen that model before....can't wait to hear you top end with the new plate!
frogII
Post: # 16959Post frogII »
That is one nice looking Vamp and for that price heck ya
will probably be my next boat , when the other projects are out of the way
keep us posted with pics and numbers
Post: # 16960Post RussF »
looks good .....got anymore pics......we like .................................PICS.................. :o
nosboss
Post: # 16985Post nosboss »
Nice hydrostream!
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
