76 vector restore
kytekeith
Re: 76 vector restore
Post: # 15179Post kytekeith »
100_0555 (Copy).JPG (408.46 KiB) Viewed 7898 times
Doing the same thing on the other side. I will let it cure for a couple of days before I grind the edges and lay down the 1708.
265mercman
Post: # 15199Post 265mercman »
loooking good love the look of balsa but the foam core seems to be good also if you get the 3/4 or 1/2 inch no rotting in that stuff either lol
kytekeith
Post: # 15639Post kytekeith »
100_0856 (Copy).JPG (646.86 KiB) Viewed 7831 times
After another trip to the supply house to pick up 4 more gallons of resin I layed the 1708 over the other side of balsa. Now I am looking at the dark hole that needs grinding, I am itching just thinking about it.
100_0857 (Copy).JPG (590.25 KiB) Viewed 7831 times
Looks like time to get new tyvek suit and 36 grit disk.
Post: # 15643Post VultureNo2 »
Looks great. Keep it up. Did you get enough resin up in the bow? that looks a little light which makes me wonder if it is stuck down properly or has some air pockets in it. Not saying it's wrong. Just though it looks an awful lot like the part I did and had to pull off and re-do. I ended up going through a lot more resin then I thought I would also. Bill
kytekeith
Post: # 15644Post kytekeith »
VultureNo2 wrote:Looks great. Keep it up. Did you get enough resin up in the bow? that looks a little light which makes me wonder if it is stuck down properly or has some air pockets in it. Not saying it's wrong. Just though it looks an awful lot like the part I did and had to pull off and re-do. I ended up going through a lot more resin then I thought I would also. Bill
No resin yet, havn't finished grinding. Just got back from lowes with new tyvec suit and 36 grit disk. Now I can have some fun.
kytekeith
Post: # 15649Post kytekeith »
2 hours of grinding and enough for today.
100_0858 (Copy).JPG (466.35 KiB) Viewed 7814 times
Post: # 15653Post YDOC462 »
Looking great!
kytekeith
Post: # 18312Post kytekeith »
I am off work for a few days and the weather is in the 80's with no rain.
100_1521 (Copy).JPG (198.62 KiB) Viewed 7598 times
100_1520 (Copy).JPG (203.3 KiB) Viewed 7598 times
Today I will fill the voids around core.
nosboss
Post: # 18354Post nosboss »
Looking good! I'm going through a ton more resin than I expected on my ventura rebuild. I used 11 gallons already and I'm not sure I will be able to finish it with another 5! I love the look of the balsa core btw.
'76 ventura II
'87 200 evinrude xp
'79 baja 180ss
Post: # 18357Post Hippie459MN »
I have 10 into my Vulture so far and I bet I will use another 10 easy. :shock: :? :o
