Ignition help
Ignition help
Ok I'm in the process of converting to a push button start and I'm n a little rut! I get the motor to turn over but won't start! I tapped the yel/red wire! So can it be that the ignition is still off? I looked at a mercury's color code and I think I may have to tap some other wires! Any help would be greatly appreciated!
Almost Don't Count
Re: Ignition help
More than once, I've had a similar problem only to find that the kill switch had been tripped...
Re: Ignition help
Yes to start it the key must be on! And I need to be able to flip a switch and push the start button!
My kill switch was on!
Almost Don't Count
Re: Ignition help
You need a in-off switch with batt. Power in and purple out so ypu can power the purple.
[ Post made via HTC A6277 ]
Re: Ignition help
Yeah I have the switch and battery to it!
Almost Don't Count
Re: Ignition help
Stupid question, but I've been caught.... Shifter in neutral position? There's an interrupt circuit, right?
[ Post made via BlackBerry ]
- 7250 Views
- Last post by Dmick
Nov 18, 2011 10:09 pm
- 8714 Views
- Last post by dehydrated
Feb 04, 2012 10:28 am
- 4871 Views
Dec 08, 2011 11:10 pm
- 3550 Views
Nov 17, 2011 8:12 pm
- 33Replies
- 11804 Views
Dec 05, 2011 1:09 pm
