76 vector restore
brianincc
Re: 76 vector restore
Post: # 9069Post brianincc »
The floor in my 73' is narrow like yours.
kytekeith
Post: # 14305Post kytekeith »
Man, time flies by, I can't believe its been almost a year since I have posted anything. I have made some progress but not as much as I was expecting when I started this project.
I am trying to post some pics but they are too large. Any suggestions?
100_0197 (Copy).JPG (116.15 KiB) Viewed 1823 times
Thanks Hippie, I might have figured it out, not sure what size to use.
100_0198 (Copy).JPG (106.34 KiB) Viewed 1823 times
These are pics of how not to do.
My plan was to lay down the 1708 and also embed the core at the same time.
On the left side of stringers I mixed resin to hot and was unable to complete before gelling occured, had to grind all of it back out.
On the right side I mixed a little less hardner and was able to put down the 1708 but my core didn't set so I had to remove the core only.
Has thanked: 365 times
Post: # 14306Post Hippie459MN »
kytekeith wrote:I am trying to post some pics but they are too large. Any suggestions?
Welcome back. :up: I have been wondering where ya have been. lol
Here ya go - http://www.hydrostreamforums.com/resizeimages
There is a ton of info in the Hydrostream Knowledge Base. :up:
kytekeith
Post: # 14351Post kytekeith »
Got 2 layers of 1708 layed back in on the left side and also the core set on the right side.
I layed the core in this time not bitting of more than I could chew. I only layed a 2 inch strip along the stringer first and the layed the remaining 4 inches second. Also before I set the first core in I filled the void of the strake with west system 407 fairing compound so the core could lay flat.
100_0088 (Copy).JPG (129.77 KiB) Viewed 1823 times
The void under the squegee is where I used the fairing.
100_0457 (Copy).JPG (107.82 KiB) Viewed 1823 times
varmint1
Post: # 14352Post varmint1 »
Looking good, I always heard that if you f$&k with Fiberglas just redo it, I had some mistakes with mine and like you had to grind and refiberglas, just some learning experiences keep the pictures coming
kytekeith
Post: # 14353Post kytekeith »
varmint1 wrote:Looking good, I always heard that if you f$&k with Fiberglas just redo it, I had some mistakes with mine and like you had to grind and refiberglas, just some learning experiences keep the pictures coming
Experience is the best teacher.
Although it sucks to regrind.
kytekeith
Post: # 14354Post kytekeith »
I used my 4 1/2 inch grinder with cutting wheel to trim edges of core almost even with floor register.
100_0460 (Copy).JPG (104.66 KiB) Viewed 1816 times
100_0461 (Copy).JPG (109.31 KiB) Viewed 1816 times
Used the same system on other side of stringer with laying 2 inches of core. This way takes more time but I know the core is embeded well.
Post: # 14361Post VultureNo2 »
Glad you are back on it. Bill
Post: # 14362Post YDOC462 »
VultureNo2 wrote:Glad you are back on it. Bill
Yep, keep at it and keep us posted.
kytekeith
Post: # 14368Post kytekeith »
Thanks guys, with a little luck I might be ready for a power supply by summer.
100_0462 (Copy).JPG (110.79 KiB) Viewed 1792 times
Laid the rest of core up to the floor register and filled the void on one side with fairing compound.
100_0466 (Copy).JPG (121.77 KiB) Viewed 1792 times
Ran out of resin so I guess it will be next week before I will re-up.
