Ya know it wouldn't be hard to slap the 3.0 on the virage and see how you like it. The vipers were designed around the inlines so even the small v6's are more than they were designed for, now the virage is built for a v6 it might handle fine.fla.viper wrote:thanks chet, you are the best! i actualy thought my motor was a 2.4. i. guess ill run it on the virage, till the viper is ready for it, while i figure out the best way to replace it. i still have the '99 3.0 250 efi on my seabird. iv seen another virage with a 3.0. what do you think?
tx, mike
XR4 MODS?
Re: XR4 MODS?
Re: XR4 MODS?
Chet you said that 150s are 2 liter and the 200s are 2.4 or 2.5 liters. My 150 is a 2.5 and my dads 150 is a 2.4 with the chrome sleeves and my old black max 175 was a 2.4 with chrome sleeves.
Re: XR4 MODS?
hummmm I always thought that the XR4 150 was different from a regular 150....77viper wrote:The 150 and 200 are completely different in bore sixe and porting. As far as mods go have the heads cut, that's the best bang for the buck. Put fiber reeds in it as a preventative measure, remove the exhaust liner if you want it a little louder. That will give you a little boost without hurting reliability. If you want more out of it than that it is more cost effective to just go with a 200.
A bridgeport has such a wide exhaust port it needs a bridge in the middle to keep the rings from catching. The porting is a lot different than a fishing motor 2.4.
Re: XR4 MODS?
I was wrong about the displacement of the 150 motors. You can see the differences here http://www.advancedsleeve.com/mercurymarine.pdf
Re: XR4 MODS?
i havent been on line for a while, im an automotive a/c mechanic in florida so thing get really crazy this time of year. Chet ive been wanting to put the 3.0 on the virage for a while. my 3.0 has a 25 inch mid. the 150 has a 20. the 150 is mounted as low as possible on the jack plate. the jack plate as low as possible. the prop shaft is about 2 inches below the drain plug. i think i can adjust the extra 5 inches out plus more if need be. what do u think? if i had a 20 inch mid, it would allready be on. tx mike77viper wrote: Ya know it wouldn't be hard to slap the 3.0 on the virage and see how you like it. The vipers were designed around the inlines so even the small v6's are more than they were designed for, now the virage is built for a v6 it might handle fine.
- 5751 Views
Nov 23, 2010 5:39 pm
- 12724 Views
- Last post by iqraceworks
Sep 06, 2012 5:46 pm
- 5233 Views
Nov 25, 2010 8:19 pm
- 73Replies
- 38260 Views
- Last post by Rut311969
Aug 02, 2011 9:49 am
- 6156 Views
Nov 26, 2010 6:14 pm
