Laser II Prop
Laser II Prop
I tested my new (used) laser II prop on the Viper today. It's a 24P on an old Merc 850. Top of prop hun was about an inch below bottom of pad. However, it seemed like the motor was too high. It got out of the water OK, but never really hooked up. 40mph at 6200 rpm (I know, I didn't leave it there for long) and a pretty big rooster tail. Any sugestions on set-up? I was going to lower it an inch or two and try again, however it will be a few days before I can get out again. Pics attached. - Chris
- Viper2.jpg (94.84 KiB) Viewed 10743 times
- viper1.jpg (91.53 KiB) Viewed 10743 times
Re: Laser II Prop
Couple more pics. I'm shooting for 50 mph.
- Viper 4.jpg (87.05 KiB) Viewed 10741 times
- Viper3.jpg (86.87 KiB) Viewed 10741 times
Re: Laser II Prop
You may be right. However, my only other experinece with boats like this is my Voodoo w/ a 70 OMC. It has a "Raker" prop and from what I can tell, it's the same as the Laser II. The Voodoo behaves pretty much the same. Throws a rooster tail for a bit, then "hooks up." The bow jumps up and the rooster tail goes away and you feel a thrust of acceleration. The Viper just can't get up on the "step." Oh, and the prop shaft on the Voodoo is about an incher higher than on this boat. It tops out at 60.
Re: Laser II Prop
Sounds like bringing the engine down an inch or so wouldn't be a bad idea. Think your engine would be able to handle another 2 inches of pitch? Maybe a chopper 2?
Re: Laser II Prop
Is it just me does that look like a 25" motor?
Re: Laser II Prop
If it is I would put a 20" motor (Or mid if ya wanna change it) and lower that motor a bit and start with the prop shaft about 2 inches below the pad without a low water pickup. That motor sitting so high could be some of the problem. But then again, what do I know, I havent even driven my boat yet. LoL
Re: Laser II Prop
Hippie I can't wait til you get your boat flying. I have a feeling we will all be trying to catch up!Hippie459MN wrote:If it is I would put a 20" motor (Or mid if ya wanna change it) and lower that motor a bit and start with the prop shaft about 2 inches below the pad without a low water pickup. That motor sitting so high could be some of the problem. But then again, what do I know, I havent even driven my boat yet. LoL
- 133371 Views
Feb 22, 2019 11:52 am
- 273409 Views
Dec 13, 2019 7:07 pm
- 115982 Views
Feb 24, 2019 10:11 am
- 144268 Views
- Last post by CleanV-King
Dec 29, 2020 11:32 pm
- 127130 Views
- Last post by dehydrated
Mar 08, 2019 11:15 am
