Page 1 of 1
water pressure gauge
Posted: Mar 13, 2011 9:16 am
by streamin_demon
how do i hook up water psi gauge ? tap into hose going to piss stream where it exits block and what king of hardware is needed have livorsi gauge
![Boating :boating:](./images/smilies/boating.gif)
Re: water pressure gauge
Posted: Mar 13, 2011 10:33 am
by ccrick
What engine? On my merc, there is a fitting on the top of the block rearward of the flywheel.
Posted: Mar 13, 2011 7:52 pm
by LSaupe
On my Johnson I have it hooked up in the line going from the block to the tell tale (piss tube). Uses a simple T. Works well. There might be more optimum locations, but that is where mine was set up so I just left it there.
Posted: Mar 13, 2011 8:43 pm
by silkeysak
On V-6 loopers there is a brass nipple on the lower right (from the back). Remove the nipple and replace with the push in fitting that comes with the gauge, Just did mine last week. Good Luck!
