water pressure gauge
how do i hook up water psi gauge ? tap into hose going to piss stream where it exits block and what king of hardware is needed have livorsi gauge
Re: water pressure gauge
What engine? On my merc, there is a fitting on the top of the block rearward of the flywheel.
On my Johnson I have it hooked up in the line going from the block to the tell tale (piss tube). Uses a simple T. Works well. There might be more optimum locations, but that is where mine was set up so I just left it there.
On V-6 loopers there is a brass nipple on the lower right (from the back). Remove the nipple and replace with the push in fitting that comes with the gauge, Just did mine last week. Good Luck!
- 3383 Views
- Last post by terry2
Oct 09, 2015 11:34 pm
- 6781 Views
Oct 10, 2015 6:57 am
- 7044 Views
- Last post by mtkst19
Oct 11, 2015 9:37 pm
- 6874 Views
Apr 19, 2017 7:34 am
- 3348 Views
Oct 31, 2015 10:32 am
Users browsing this forum: No registered users and 42 guests
