prop setup
Re: prop setup
Welcome to the site.
Do you have a low water pickup?
I would pin the bearing carrier if you run a surfaced prop.
If not get a water pressure gauge and go up in 1/4" increments until you start to loose water pressure, then go down 1/4".
If you do have a nosecone start at 1" below the pad and work your way up.
There isn't a magic setting for all hulls as they will be different weights in different places so it's a trial and error. A gps unit will also help because after a certain height your prop will start to slip and you will loose speed.
- 7204 Views
- Last post by varmint1
Dec 25, 2010 5:28 pm
- 7139 Views
Dec 24, 2010 11:29 am
- 4225 Views
Dec 28, 2010 11:05 am
- 3053 Views
Dec 27, 2010 10:21 pm
- 7396 Views
Dec 31, 2010 3:30 pm
