You have a website, don't you? Why not just FTP the images to its own directory and then IMG tag them here?alaskastreamin wrote: ↑Sep 12, 2019 11:14 am My image hosting (free) site has closed down so this is my first attempt at uploading pictures directly . I hope they load in the right order......
Re: Glastron GT-150 - Hull mods to make it handle 150 HP
Cause I don’t know how to do that. Lol!!
I asked Caprice and she said I need to learn this. She put the site together. She is so busy, I’m going to get a lesson this winter.
Saturday November 2nd.
Good weekend to put on the pad.
De-rigged the hull and flipped over, formed up lifting strake extensions and laid up with a foam core.
I added in some cobalt To the resin so I could shape the layup 15 minutes after cleaning the tools.
Should be able to get the pad laid up, shaped and in gel by the afternoon.
- 9EBF5F6C-13D5-4322-BC36-21B24ACAE556.jpeg (2.54 MiB) Viewed 18693 times
- 7A9A3D6B-C38C-4B48-B192-418876881B59.jpeg (1.59 MiB) Viewed 18693 times
- DCD909B3-63F9-4645-90D3-F91CAFEA5356.jpeg (2.56 MiB) Viewed 18693 times
- 6332D797-50D7-4169-A66A-CA2DC763DFE9.jpeg (2.56 MiB) Viewed 18693 times
- DCA198FA-6763-4764-99C1-0CA993DBC3DB.jpeg (2.46 MiB) Viewed 18693 times
- 6B60EDCA-2E9C-4883-B9D3-F438585C6F4B.jpeg (2.82 MiB) Viewed 18693 times
- FAF4C031-1B12-416F-9BD1-9D7AD43FEF58.jpeg (2.8 MiB) Viewed 18693 times
- 439C6609-6E16-494A-8ABF-259914249A66.jpeg (2.91 MiB) Viewed 18693 times
- 02FA32B2-35D3-4AD2-B7C6-1904813CAC69.jpeg (2.7 MiB) Viewed 18693 times
- 703FAD55-63F4-45AD-9288-EB5A8A9FF89A.jpeg (2.58 MiB) Viewed 18693 times
Following glad to see this project is in the works
Sunday I got the pad laid up but had a couple "drop in's" visitors and didn't get pictures. Will tonight though.
I hot glued some forms and got them level.
- IMG_2502.jpg (89.23 KiB) Viewed 18677 times
- IMG_2501.jpg (78.82 KiB) Viewed 18677 times
- IMG_2500.jpg (69.41 KiB) Viewed 18677 times
- IMG_2499.jpg (108.47 KiB) Viewed 18677 times
- IMG_2496.jpg (68.84 KiB) Viewed 18677 times
Looking good. What are you going to use for the pad material?
Kevin, I am using 8# urethane foam.
Once the forms are hot glued down, I lay up a couple layers of CSM (chop strand mat) and cloth on the hull, up the inside of the forms and let drape over and outward. Then I bed in the foam and then fold the extra glass back over the foam. Then I put down a CSM , woven roving and a CSM. Grind flat and pop the forms. Leaves nice clean sides to the pad. I have the hull level and am now fine tuning the pad then gelcoat and re-assemble.
- IMG_2512.jpg (83.5 KiB) Viewed 18673 times
- IMG_2502.jpg (89.23 KiB) Viewed 18673 times
- IMG_2501.jpg (78.82 KiB) Viewed 18673 times
- IMG_2499.jpg (108.47 KiB) Viewed 18673 times
After checking with a 5’ straight edge( I like using aluminum as it leaves black marks when you slide it slightly showing your high spots) I found a few slight waves in my layup.
I mixed up some glass bubbles and resin to form a thin putty. A couple applications got the pad true .
Mixing the gel coat was a pain. It is white with some black, yellow, and some red. Glad it’s the bottom cause I definitely don’t want to do a topside repair.
- 6C6C7087-78ED-4B30-8340-9A95E9C93380.jpeg (2.2 MiB) Viewed 18665 times
- D984C782-4D7A-4FF2-8335-95464CB7D9C3.jpeg (2.3 MiB) Viewed 18665 times
- D999361F-FE9A-4A79-9D99-C2D298D02206.jpeg (2.01 MiB) Viewed 18665 times
- C6B3B6A1-9D07-4226-BF75-920E10ADB3C8.jpeg (2.41 MiB) Viewed 18665 times
- 9C3058E3-B988-4E14-BE21-286121A1C154.jpeg (1.76 MiB) Viewed 18665 times
- 5ACBAA23-C25C-4CBE-A262-DB1FF157523B.jpeg (2.44 MiB) Viewed 18665 times
- 83701A4A-E133-4B7D-B785-DAD0A813E5DF.jpeg (1.85 MiB) Viewed 18665 times
- B8C3CB26-D83A-4924-910F-A3BA030978A8.jpeg (2.03 MiB) Viewed 18665 times
Wow! That's coming along great! Dang wait to see how it performs with a pad under it. Great job Ron!
Get it done we have a airport landing to jump over
- 6342 Views
- Last post by Sam007
Jul 31, 2013 8:46 pm
- 8680 Views
Jan 24, 2012 10:41 am
- 5435 Views
- Last post by smiles
Mar 08, 2012 10:36 am
- 5758 Views
Jan 24, 2012 9:35 pm
- 9149 Views
Feb 09, 2012 4:53 pm
