24 Raker on Viper
Re: 24 Raker on Viper
well ive been playing around in my viper with this new 24 Raker prop not real sure how fast it is feels quicker but is this little hard to control it's great untill you start to trim up it starts hoping around the more gas you give it the smoother it rides untill it starts to chine walk best i can describe it, then your just trying to hold on i know its not a big speed demon but I can't really open it up any ideas how to gain some control.
Thanks, Ryansviper >)))>
Do you have good, tight dual cable steering? How about solid motor mounts? Those two are a must for drive ability and safety. The higher you get the propshaft also helps but will require a low water pickup on the gearcase.
I have dual cable steering not sure about solid motor mounts what would I be looking for there? The motor has LWP but no set back the transom was raised the center of the prop shaft is about 2" below pad when the motor is trimmed all the way down.
I've had really good luck with Rakers on my Vegas XT.
1989 Vegas XT w/ 3.0 OMC Looper
do you still happen to have this boat? i have a viper that is very similar to yours and was wondering if you ever got your boat lined out.
- 3837 Views
Aug 28, 2012 8:47 pm
- 9004 Views
- Last post by Varigeo
Sep 25, 2012 8:24 pm
- 3419 Views
- Last post by HST4ME
Aug 31, 2012 1:09 pm
- 9273 Views
Sep 02, 2012 4:38 pm
- 4154 Views
- Last post by beavertonae-21
Sep 05, 2012 7:18 am
