79 200merc idleing problem
ok so me and tnriverrat when't and picked up a 200 merc today 79 model and the motor wouldnt start so i adjusted the timing got it fired up ran good but the idel was probally around 2grand or so no rpm gauge yet but anywhom there is no idle adjustment on the carbs after it was running and warm i adjusted the idle timing screw and tryed to get the idle down the trigger arm on the flywheel went as far as it would go and still idled way to high and the idle timing was around 4 atdc so how do i get this motor to idle down any suggestions will be thanked
Re: 79 200merc idleing problem
Check for air leaks
[ Post made via HTC A6277 ]
okie thanks chet we will check the air hoses from and around the front block
- 5526 Views
Aug 19, 2010 11:09 am
- 14948 Views
- Last post by RedDemon
Aug 22, 2010 2:11 am
- 5421 Views
Aug 19, 2010 7:56 pm
- 5274 Views
Aug 21, 2010 8:09 am
- 7089 Views
Aug 22, 2010 5:13 pm
