VULTURE recore
varmint1
Re: VULTURE recore
Post: # 13527Post varmint1 »
Looking good Kenny, looks like your a professional, keep the pics coming
KENNY
Re: VULTURE recore
Post: # 13645Post KENNY »
Here is the latest update. The core in the front is all glassed in and done. The core in the back is all glued down and will be glassed over today I hope. I am almost out of resin and dont think I have enough to do the whole job so I am going to wait. More has been ordered and should be here today. Hippie, just a reminder, I know you had to stop working on yours for a while but before you put your floor on make sure you drill a hole in the back of your stringers to let any water that might get under the floor away to get out.
Re: VULTURE recore
Post: # 13646Post 77viper »
Looks killer!
[ Post made via HTC A6277 ] Image
Re: VULTURE recore
Post: # 13647Post YDOC462 »
Looks awesome man!
Re: VULTURE recore
Post: # 13648Post Hippie459MN »
Looks awesome!!! Great job so far.
Re: VULTURE recore
Post: # 13652Post VultureNo2 »
Everything looks exactly like mine did as far as core and front floor. Great job. Keep it up, you'll be on the water in no time. Bill
KENNY
Re: VULTURE recore
Post: # 13668Post KENNY »
Today I painted the inside of the boat with a expoy paint,this stuff dries hard as a rock. Then I glued down the front half of the floor.I left the back half out because I need to drill and bolt the L brackets that go on the bottom of the vulture. I have to change mine because they were pretty much rotten away. After I bolt them in I will glue the back half in. I am going to try the boat with out putting the vacuum tubes back, If it don't break loose I can always redrill them.
I have a ques. Does anybody know were I can get the extension for the steering wheel? I see you have one on your boat Hippie.
Re: VULTURE recore
Post: # 13669Post YDOC462 »
Rex marine
Re: VULTURE recore
Post: # 13670Post RussF »
Kenny maybe you 'll be done for the no name event in June in upper state New York........LOOKING GOOD............ :up:
varmint1
Re: VULTURE recore
Post: # 13672Post varmint1 »
Looks awsome Kenny
