high five prop for sking
Has anyone used a High five prop on their boat? I have a ventura 2 with 200 merc and sportmaster lu and need a prop to pull my grandson sking, have removable ski pole also which should help, have alot of different props 3 blades, 4 blades and just read some things about the 5 blade for sking. Thanks for any help or info on this matter...
Re: high five prop for sking
Hi, Yes 2 of them do a good job but had just read about how good the 5 blade was for water sports, sking , wakeboard , tube, etc and just thought I would ask if anyone has tried one, they say they are super smooth and pull real hard even when turning, dont know if I need another prop, have 10 now , just saw a few on ebay and thought if they are that good I might bid on one...what I didnt understand was they say what ever pitch prop you run now and if it turns the rpms you want thats what pitch you need in a 5 blade...seems like it would be alot of prop...Thanks for the reply
Hi RussF, Thanks for the reply, I will make a list of props and let you know this weekend, also if I can ask you I have been trying to get some rubber rub rail to go over my stock alumimum rub rail so that I dont have to pull boat apart in 2 peices, boats do strange things when you do that...I have been everwhere and the best so far I can come up with is West marine, they want 565.00 for 100 ft, which I dont need that much, it is from Taco # v11-0232. that makes it like 5 dollars a ft! any ideas? thanks
I know the builder of my boat got the rub rail from Hamilton marine in Maine But give me a couple days to call him and see if hes got any around
I'm not sure if this is what you are looking for but here is some rub rail. http://minneapolis.craigslist.org/hnp/boa/2725063650.html
My vegas had a high five on it when I bough it it is a great watersport prop. They are not as efficient as a 3 or 4 blade that's why you can get away with such a tall prop. I still have the 25 pitch if your interested.
77viper thanks for the info, they sure are proud of the rub rail at over 5 dollars a ft! think I would rther buy a prop or a performance part for the motor, never knew that rub rail was so costly..live and learn...thanks for the info on the prop also, could you email me a pic of it, morrisonsl@planetc.com and price...what hp motor were you using it on and if you can remember what rpms were at wot...thanks for any info and your help..
On my Venus, I run a 23 high five for sports. It works outstanding. I run with little to no trim and it has minimal torque steer. I have a 200 Yamaha with a bobs Bigfoot. I will say, it likes to be sunk real far down on the plate or it will cavitate like hell. I can run with 6 or 8 on the boat and 3 kids on the tube and plane at 17-18 mph.
Now with a 24" trophy plus prop....it totally sucks..it will take forever to plane with a load! and bow lift is so bad you can't see where you are going unless you are running 28 mph, and then the kids are screaming to slow down. Even with it all the way trimmed down, it is hopeless...and if that is not enough, it will overheat in about two laps of the lake bay.
That High Five is pretty much the only prop I run on there now. It's no speed demon and only runs in the 60's, but it works for everything, no matter the load.
Great recreation prop.
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
87 Valero- How dangerous to run with rotten core?
Last post by orig-owner87valero « Jan 14, 2015 12:10 pm - 10Replies
- 16197 Views
- Last post by rossi
May 07, 2015 7:52 pm
- 6156 Views
Jan 17, 2015 8:18 pm
- 19Replies
- 19731 Views
Apr 02, 2016 4:48 pm
- 5378 Views
- Last post by proprider
Jan 26, 2015 9:01 pm
- 25Replies
- 20552 Views
- Last post by nitro_rat
Mar 10, 2018 1:51 pm
