Primer???
Primer???
Ok, after reading other post, I have also decided I will gel my viper instead of painting it. I will be adding the Duratec addative to the gel. My question is, do I have to prime the boat first just like I was using paint or can I gel over the old sanded gel coat.
Thanks
Thanks
Re: Primer???
I was goina ask the same thing! Looking forward to the replys
1982 Hydrostream Vandal
Currently restoring...
Re: Primer???
Im with you two. I would like to know this also for when I do the bottom of my boat.
Re: Primer???
Spraying gel is not all that simple. Gel, by itself, will not completely harden, even with a catylist. Also, gel is not self leveling. It will need to be wet sanded and buffed to look good.
Re: Primer???
Well, I sprayed the bottom of my Viper with white Gel and Duratec in a 2.0mm HVLP gun. It came out great! no primer. I did have to wet sand and buff, but I was very happy with the application. I have never used a spray gun before. Next is the top half. I'll keep you posted!
Re: Primer???
I heard primer will bleed through even when it dry. I would go right over the old gel. Paint can even go over jel and turn out great... just ask king gill.......... his boat is sweet. Paint over gel.
1990 Vegas XT 1997 225 Mariner Supermag
http://www.youtube.com/watch?v=9xkEQjMPJbM
http://www.youtube.com/watch?v=y-_sgtIOeoo
- Hydrostream Great - RIP
Re: Primer???
Primer is not needed. I shot the bottom of my 78 vking with gel. I mixed regular white gel with wax additive, catalyst, duraclear for shine, and thinned the mix down with medium temperature lacquer thinner. I prepped the hull buy sanding the old gel down with 80grit. Then shot 3 or 4 heavy coats. After a few days of drying i wet sanded the hull with 400, then 600, then polished it using 3M's fiberglass polish.
- 56314 Views
- Last post by Calhydro
Sep 15, 2018 6:58 pm
- 167011 Views
- 120293 Views
- 145299 Views
- 122922 Views
Users browsing this forum: No registered users and 35 guests
