Stringer placement
Re: Stringer placement
Yes and no. I guess it depends how the boats engineered.
Unlike Chet's,
My viper had, and still has the stringers bedded to the skin and core laid between and around them. The stringers were bedded in tall then routered down using a homemade jig (slides in the strakes) to ensure the floor section could be bonded to the tops of the stringers. I have seen Vipers both ways and I can only assume that they began laying stringer on top of the core in the newer boats (mine is a '76). The big argument here is that by bedding the stringers to the skin and laying core between you essentially create a sheer line at the right angle where the core meets the stringers. There are fans of both build types, both with, what I feel, to be solid reasoning but mine went back together they way it was originally constructed....only much much better.
The key here is having a solid base to work with.....either of the two ways obviously work. My boat was laid up so dry on the starboard side that once the core was removed and it sat under cover with a dehumidifier for a few days, you could peel the skin off by hand...waa-laa!!! potato chips!! The entire bottom got beefed up with a layer of cloth before the new core went in. Either way, my first trip out work me up to what a true dry/solid hull should sound like.
Jeff
EDIT: Old thread....oops...
Jeff
actually the way it was explained to me by a boat engineer was this.......the core material is there to spread impact over the surface of the hull......putting a stringer on the hull creates a shear line.....the impact stops at this line and creates a spot for the impact to stop......thus...a week spot......this is why the stringers should be placed OVER the core. There is no line for impact or stress to stop and it's distributed overa larger area......if the core becomes unatatched to the hull you have a week spot anyway and the stringers would not make a differance anyway. The stringers are there for strenth....the core is there to distrubute stress.....as both of these things add some to the other engineers look at them as seperate entities.....what carries over is a plus but really not a factor......so I'm told.....keep in mind I'm not an engineer but this does make the most sense to me.....at high speed I would want the force working against me spread out over as large an area as I can get not confined by a sheer line in the hull.....keep in mind in the water there would be two sheer lines,one on each side of the stringer.....two stringers,four sheer lines so on and so on
Did anyone notice this is different? Viper, is this right?77viper wrote:My stringers were and are over the core on my viper.
I would almost think it would be better to put the stringers over the core (like Viper 77). If the stringers were attached directly to the hull, the load would be transfered from the bottom of the hull to the stringers. In this case, the core material wouldn't affect the overall strength or aid in absorbing the impact. On the other hand, if the stringers were bonded to the core, the load would be distributed over a larger surface area resulting in less (lower) pressure points.
This being said, we're not exactly talking about the Space Shuttle here or the B2 Bomber. Meaning, the engineering tolerances are far from tight on a small boat like this and they are more than likely over-engineered either way.
Thoughts?
-Chris
Thinking about it a little more..... I would imagine that in a boat like a Viper , the pad area is strong enough with or without the core. I would think the core material is mainly to add strenght to the area of the hull between the stringers and the side of the boat. In that case, the stringers would work the same either way. Right?
Is that your boat? You could hang 2 V8s off that thing. LOL
i dont have any engineering input on stringers on top of core or direct to hull.
i bonded stringers straight to hull as it was originally and in the process of coring and glassing i DO know it would be easier glassing the core in the bow (climbing in and out) without the stringers in the way. especially those who are coring a viper/vector with the core running way up in the bow. just my opinion
- 5142 Views
- Last post by rev.ronnie
Mar 19, 2014 6:36 pm
- 6590 Views
- Last post by red4020jd
Feb 18, 2014 7:19 pm
evinrude 235 hp crossflow lower unit removal/replacement
Last post by mitchielpricer « Feb 24, 2014 6:55 pm - 4Replies
- 3869 Views
- Last post by bruzercomp81
Feb 25, 2014 11:20 pm
- 7869 Views
Apr 07, 2014 9:10 pm
- 21331 Views
Apr 07, 2014 9:15 pm
Users browsing this forum: No registered users and 41 guests
