Bought a boat that was supposed to be turn key. Well it wasn't, floor and stringers are rotten... Motor problems and more since buying it.
There is 20% moisture at the transoms in some areas, does that mean it needs to be replaced as well?
Thanks Mark in Kingston On.
88 hydrostream vission with a 150 Merc.
well here we are
Re: well here we are
Dont forget about the core also.
Read here if you're not familiar with it - https://www.hydrostreamforums.com/the-core-what-is-it-and-where-it-is
The add pictures button seem to work here. What is the exact problem you are having?
Yep had not forgotten about it. Seems solid, but was going to drill a couple spots near the back to see if it's pooched, not sure if there is a better way to go about it.
Any advice would be appreciated.
98% of the time, if the floor and stringers are rotten, so is the core. Sadly... We've all been down the core job road before so I feel your pain. Good news is, once you fix it right, it will probably outlast you.
Hydrostreams used a proprietary rub rail and was made in house so you will not find original rub rail.
- 48754 Views
- Last post by Vegas XT
Apr 18, 2009 8:39 pm
- 29920 Views
- Last post by oldskier
Apr 27, 2009 8:51 pm
- 64793 Views
- Last post by coupe
May 11, 2009 6:37 am
- 46627 Views
- Last post by Enticer1
May 14, 2009 11:36 am
- 41387 Views
- Last post by king gill
May 17, 2009 5:35 pm
