Hey Guys ,
I am in process of rebuild of 79 vector , I had the middle pad filled and straighten as i did my last 79 vector many many years ago . Has any one straighten , the next set of chimes , I saw they had the hook in them like the very bottom had , just wondering if the next set of chines were strait would it help eliminate the side to side rock while throttling to WFO. I have also cut and removed the floor and balsa core which was rotted as most are and plan to go back with coosa blue water 26 for stringers and floor if i put a floor back in it . Still need to cut old transom out and will also use composite on it as well . any input would be greatly appreciated . i will also post pics as i process thru this super awesome river ride . Got a 2.5 planned for power ,15 inch and sporty lower
79 Hydrostream vector rebuild
Re: 79 Hydrostream vector rebuild
How is the rebuild coming? Do you have any pics to post.
I just started redoing a 75 Vector a few months ago. The core is almost out, and I plan to start on the transom soon.
The "hook" in the pad of the vector is actually a wedge and not a hook. Howard put that there as they were getting super flighty and the very slight wedge was helping keep the nose down without loosing any speed. The wedge is not a big wedge at all but enough to make them much more manageable. As for the chines, Im not sure what you mean by a hook in them. The chines are pretty much out of the water once you're up on the pad. If you are getting bad chine walk then the setup needs some work.
- 2725 Views
- Last post by frogII
Apr 13, 2011 8:52 am
- 4913 Views
Apr 14, 2011 4:19 am
- 3346 Views
Apr 13, 2011 8:10 pm
- 3770 Views
Apr 16, 2011 1:34 pm
- 6981 Views
Jun 16, 2011 11:01 am
Users browsing this forum: No registered users and 12 guests
