Fuse box necessary?
Fuse box necessary?
Just making a list of things I'll need to purchase over the winter, and was wondering if a fuse box is necessary or not.
I'll be running a 6-switch gang switchbox "control panel" for my electrical components. Similar to this:
- bilge pump
- navigation lights
- interior lighting
- stereo
- (spare)
- master power
Should I also invest in a fuse box?
Thanks guys...
- bilge pump
- navigation lights
- interior lighting
- stereo
- (spare)
- master power
Thanks guys...
- Been thanked: 80 times
Re: Fuse box necessary?
I am going to be running a fuse block and relay panel. Im going to get to work on getting it wired up this weekend hopefully. I plan to add a radio eventually, the lights for the gauges, navigation lights, bilge pump, etc... I have had stuff almost burn down in the past from not having fuses so if I can fuse it, I am going too. lol
Good to know.
Now, where would an ideal place be to mount it?
Im going to mount mine under the deck just behind the dash as close to the center as I can I think. Going to use some 1/2 inch marine ply I have left here and mount everything then put t-nuts in the wood and then glass it under there. Thats my thought anyways. Im going to get it laid out this weekend and see where it will work out best.
Same switch panel I used in mine. I bought a fairly large fuse panel, mounted it to the back side of the dash.
Blue Sea Systems Fuse Block ST Blade with Ground Cover
More than I'll need, but can wire +12v, switched ignition and bussed ground.
I ran a fuse panel for everything but the gauges and trim switches. The fuse under the cowl at the starter solenoid is sized to run the harness off the motor control harness and accessories.
Lights, bilge, stereo, etc should come off a separate circuit. I put a 20-25 amp fuse right at the battery and a #10 up to the fuse panel then the smaller fuses on the panel run to the accessories. Of course, I run a #10 ground as well and tie in a jumper to a gauge close to the ground lug on the fuse panel or ground bar just to tie the two ground systems together.
Yes. I believe #10 AWG is the size for 25 amp. #12 - 20 Amp, #14- 15Amp and so on..... Don't let the wire be your fuse.
- 81575 Views
Mar 10, 2022 10:03 pm
- 99758 Views
Mar 25, 2022 2:11 pm
- 100344 Views
- 105040 Views
- 65719 Views
May 22, 2022 8:22 am
