After I removed my rotten transom, and ground the old wood off of the skin, I’ve noticed it is kind of wavy and not straight. Is this something that will go away after I put a few layers of glass over and kept it straight before I bed the transom in?
Transom exterior skin after transom removal
- Has thanked: 2 times
- Been thanked: 3 times
Re: Transom exterior skin after transom removal
It should go back to being flat after putting the new transom in.
When you clamp it, a few things to consider.
Use as many clamps as you can. Always start at one end and clamp progressively to the other, and bottom first then the top. This way it helps move air pockets up and out.
Don't place the clamps directly on the transom, especially if you'll be using the Vise-grip style hand clamps. Use boards of 2x6s or 2x8s between the clamps and transom. This distributes the clamping pressure over a wider area, and prevents "dents" being created due to the pressure.
If you have a piece available, on the back outside part of the transom use a piece of plywood 1/2" or thicker between the clamps and transom. This will help flatten the skin as you'll essentially be sandwiching the exterior skin between it and the new transom.
Awesome info. Thanks!!
1977 cocoloco varmint
1988 reaction 19
1988 reaction 19
- 6992 Views
- Last post by Slide
Sep 05, 2013 10:17 am
- 7377 Views
- Last post by Steve Slechta
Sep 05, 2013 11:05 am
- 8563 Views
- Last post by nosboss
Nov 28, 2013 11:39 pm
- 6755 Views
Sep 10, 2013 12:03 pm
- 5360 Views
- Last post by quinten
Sep 10, 2013 5:42 pm
Users browsing this forum: No registered users and 59 guests
