Trying to set up VKING Yt it's a 2003
Re: Trying to set up VKING Yt it's a 2003
Battery back of boat on passenger side gas tank center of boat in back
My cousin had a similar setup on his VKing several years back.
He got 98mph running a 14.5" x 30 pitch cleaver.
Hippie actually created a thread about his boat.
http://hydrostreamforums.com/viewtopic.php?f=5&t=472
I threw up a video on YouTube of me in it with him driving (obviously) back in 08. Its crappy video quality and over 7 minutes long.
I was trying to get closeups of the tach and speedo but it was a bumpy ride. I eventually gave up and got some over-the-windshield shots.
We got around 85mph. Medium chop on the lake in spots.
But that Merc screams at 6500+.
https://www.youtube.com/watch?v=9qphMYoolxY&t
He says that your 84 sounds about right for your 26 chopper. Says you'd probably get 100+ with a 30-32 chopper.
And you shouldnt need a jackplate with a 15" mid.
Or are you talking about setback instead of height?
The Chopper is killin ya. When you get to near the level of the pad, Choppers run out of bite real quick. Send it out and have cup added, that will wake it up. I think you'll want more pitch too, what rpm are you turning?Junior stanley wrote: ↑Mar 28, 2017 7:30 pm I have been 1/2 above no lift almost ride nose down running a 26 chopper I have trying a few different props now
I can turn it over 7 I think I have turned it about 7600
Something is not right there. With a 26 that thing should want to go over 8000.
Your correct I have turned it over 8
U think I need to just go up 1/2 inch above the pad
It needs to go higher, but going higher is meaningless without a lot more prop.
Setup is a combination, there is no single fix.
True I have a buddy that has a 30 et I going to try it
It should haul *** with that.
- 6449 Views
Mar 04, 2013 10:35 am
- 3376 Views
Mar 01, 2013 5:48 am
- 7518 Views
Mar 04, 2013 10:36 am
- 3036 Views
- Last post by QuarterHorse
Mar 01, 2013 7:10 pm
- 3172 Views
- Last post by Sonik
Mar 01, 2013 7:09 pm
Users browsing this forum: Google [Bot] and 9 guests
