1986 blazer won't get on pad easy
Re: 1986 blazer won't get on pad easy
Raising the motor hurts your bow lift it will cause boat to run flatter. When you lift the motor up you also cause more stern lift. If boat is solid, trim motor all the way up and push down on lower unit as hard as you can if you see the transom flex any at all the transom is bad. sounds like you have either wrong prop or a worn out prop. Props due wear out and when they due,. you will have performance issues.Also boring a motor oversize does not give it anymore power, if it does it is so minute you will not notice.
Well no telling what else the. Motor has than boring over a man that use to race built it is a 76 model 200 ,,, but transom is solid it does not move any , I think I'm having prop problem I really don't know what would be best prop for that boat that 20 pitch is not enough prop it throws the whole boat out of the water on take off just no top end not like I think it should be
- 3405 Views
Nov 12, 2010 6:49 am
- 2277 Views
Nov 12, 2010 5:16 am
- 2554 Views
- Last post by LSaupe
Nov 12, 2010 7:00 pm
- 2150 Views
Nov 12, 2010 4:15 pm
- 2190 Views
Nov 13, 2010 3:11 am
Users browsing this forum: No registered users and 59 guests
