Venus xt
Venus xt
I bought a venus xt last fall. I'm running a 150 mariner with 6" set Back and prop 2 1/2" below pad with lazer 2 24 pitch as suggested on Hydrostream history page. Runs at 5800 rpm but I can only get high 40's maybe 50 mph. Any suggestion ? Besides more power, funds are dried up this yr. I tried a laser 2 26 pitch strong pull but only 5400 rpm at most.
Re: Venus xt
I'd say start by raising the motor, it's free to do that. At 6" back, you should be able to run level with the pad. Then try that 26 again....
Re: Venus xt
Um, not likely, guess I shouldn't have assumed you were running one. So how about a torque tab, dual steering, solid mounts?? You may be safer to stay where you are...
Re: Venus xt
Hydraulic steering, no toque tab, going to order solid mounts. What about a hydrofoil? Will that help at all? I was looking at bobs true track tracker.
- Been thanked: 6 times
Re: Venus xt
If you have a water pressure gauge (if not, get one), start raising your motor and raise it as high as you can until you start loosing pressure. I bet you still get it up a ways yet. Also, I have seen people plug the top 2-4 holes on the water pickups on a stock case and get the motor up a bit more. Personally, I say invest in a cone with low water pickup.
Re: Venus xt
The hydrofoil will help out of the hole and with low speed porpoising, but that's it.
Re: Venus xt
Thanks for the input. I do have a land and sea nose cone that was on it when I got the 150. However it was installed poorly so I took it off. What should I use to put it back on? Tack weld then cover or some kind of epoxy mix?
Re: Venus xt
use marine tek to bond it on put 4 good stitch welds on cone on each side and one in the center at bottom and fill with epoxy then smooth to ur liking put itching orimer on it let it roll
- 29Replies
- 155987 Views
Jun 03, 2021 11:12 pm
- 42863 Views
Feb 17, 2021 9:22 am
- 35053 Views
Mar 01, 2021 6:53 pm
- 15671 Views
Mar 02, 2021 6:08 pm
- 15949 Views
Mar 06, 2021 9:22 pm
Users browsing this forum: No registered users and 47 guests
