It was asked that I show my gantry crane/ rotisserie I made to work on the Virage. I got my idea from Aaron at Xtreme paint while in MN. His is basically modified engine stands. I wanted to be able to pull motors and lift heavy objects so I added his design to mine.
Aarons:
The bow end....
The transom end:
Both are adjustable
Mine...
I used 3" tubing for the uprights and gussets. 3"x6" I-beam 20' long (should have got 23')
I had 3/16" plate cut to make a 16" long sleeve for the I-beam to slide into at the top of each leg. I drilled 1/2" holes on the top of each sleeve and welded 1/2" nuts so I could lock the ibeam at the span desired.
I slid a 3 1/8" ID tube over each leg for adjustable rotisserie mounts. 2 1/2" ID pipe was welded to these which allow for common engine stand heads to slide in.
The transom plate attachment is hinged and the bolts that it hinges on are in slotted holes so there is movement on both axis's. I think Aarons plate allows for more mis-alignment than mine.
My 18' boat with the attachments take me right to the edge of my 20' I-beam.
I have drawings somewhere but couldn't find them. I'll post a pict when they show up. Found it...
Roteisserie your boat designs
Re: Roteisserie your boat designs
Wow! Thats awesome. Thanks for posting this.
thanks man alot iam gona get started on one asap to paint my vking this spring again looks great as usual for ur work
Was just south for a couple days and took a few pictures of the rotisserie.
looks good iam get started on mine soon as get back home to tennessee me and ydoc is on our 3 rd motor since ive been in texas lol 2 weeks
- 4454 Views
- Last post by Bad_Influence
Mar 08, 2012 2:14 am
- 5885 Views
Mar 07, 2012 9:49 pm
- 5229 Views
- Last post by rev.ronnie
Mar 30, 2012 9:47 pm
- 6387 Views
- Last post by Rut311969
Mar 09, 2012 6:59 pm
- 12534 Views
Mar 30, 2012 5:55 am
Users browsing this forum: No registered users and 51 guests
