I have an 1985 Vulture with a 1985 200 Mercury on it.
The prior owner removed the trim guage and installed a water pressure guage.
Here is my challenge
it has one brown with tracer
black
and two purple
can anyone tell me how to connect to this Gaffrig guage?
I also need to know where is it connected on motor?
If you can send photo I would asppreciate.
I have spent many hours under dash and no luck
I can get power / light on, but that is it.
Thanks Eric
Trim guage wiring HELP me
Re: Trim guage wiring HELP me
it should have a trim sender unit mounted on port side of motor. might have to trim all the way up to see it.
I think gauge should have terminals for: sender, ground, ignition, 12v constant for light.
This will identify the gauge wiring
http://www.livorsi.com/pdf/2GITMM,GITMO,GIITMM.pdf
Brown with white tracer is the sender
Black is ground
Purple is 12V from the ignition switch
Black is ground
- 116659 Views
Jan 29, 2021 9:17 pm
- 93564 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 155659 Views
Jun 03, 2021 11:12 pm
- 42758 Views
Feb 17, 2021 9:22 am
- 34962 Views
Mar 01, 2021 6:53 pm
Users browsing this forum: No registered users and 36 guests
