new member with a 78 viper
I suspect that water will be pressured out of those holes at speed. I've never seen that before. Possibly, they first closed up the upper holes and later added the cone but didn't close the remaining holes.
Anyone else?
Anyone else?
If you have a low water pickup you are going to want to plug all of the original water pick ups on the lower. Could also cause it to pull air also possibly. You could try it as is but keep a real close eye on your water pressure and temp.
- Been thanked: 6 times
Will probably cover up the top holes. that will simplify using a hose at home when running the motor. Wondering about water pump kits and thermostats? where is a good place to buy? anything else I should know? Is there an easy way to rig up new controls to it?
well I got motivated, I know I know, I cant make up my mind... but im doing work...
- stringer1.jpg (56.86 KiB) Viewed 16773 times
- stringer2.jpg (43.92 KiB) Viewed 16773 times
- stringers.jpg (64.44 KiB) Viewed 16773 times
the seat and transom
- seat excitement.jpg (69.32 KiB) Viewed 16773 times
- hydrostream transom.jpg (42.5 KiB) Viewed 16773 times
14 inch wood steering wheel anyone? I think so
- steering wheel.jpg (45.97 KiB) Viewed 16773 times
So I've been a little busy... Haven't done all the wiring at all.. But its running! Really light and very fast for a 150.. Needs solid mounts and a jackplate.. Also need to invest in some nice gauges
- 13512190_10157038297395237_5349736639569917882_n.jpg (146.38 KiB) Viewed 16321 times
- 13533221_10157038297615237_305246267208434583_n.jpg (117.86 KiB) Viewed 16321 times
here is a link to my rig with a 2.0 running about 85. 30 cleaver and 3 inch setback with a 2:1 case and a lwp
Looks like that thing is really flyin. Very nice!
- 119104 Views
- 125507 Views
- 77869 Views
May 22, 2022 8:22 am
- 48036 Views
- Last post by blowitup
May 28, 2022 10:58 pm
- 40521 Views
- Last post by Mikem
Jun 03, 2022 7:47 am
Users browsing this forum: No registered users and 68 guests
