Prop wanted
Prop wanted
I'm looking for the right prop for my viper I have a 1982 Johnson 140 crossflow on it I want a good all around prop for two people in the boat something with good top end. Thanks all in advance
Re: Prop wanted
You will ultimately end up with at least 2 props, one for everyday riding with a loaded boat and the magic top end prop. The everyday prop should be in the 24 pitch range and the top end prop might end up about a 26. Your best bet it to get with some performance boaters in your area and try every prop you can get your hands on to see what your boat-motor combo like. I found a omc srx to work well on my viper as well as a 26 yamaha drag, I just picked up a new et but will have to wait till spring to try it.
Do you have a low water pick up on the gearcase? Hows your steering, dual cable or hyd? What about solid motor mounts? All of these things will make it safer and easier to drive over 65, once it gets on the pad.
I also have to ask if the core has been replaced?
Re: Prop wanted
I believe the boat has been reworked it seems soils and the transom was replaced and raised about 2" the motor has low water pick up with nose cone I wish there were others in the area with props for me to try right now I have a stock Omc 19 pitch prop and the boat runs good and is fairly fast I wish I could find someone with about a 24 raker up for sale
Re: Prop wanted
Thanks for all the response I think I found just what I was looking for.
Re: Prop wanted
Thanks for the response I found one on the bass cat central site that I'm currently trying to seal the deal on but the fellow kinda slow on responding to emails if it doesn't work out I sure will look you up thanks again.
Re: Prop wanted
ryansviper wrote:Thanks for the response I found one on the bass cat central site that I'm currently trying to seal the deal on but the fellow kinda slow on responding to emails if it doesn't work out I sure will look you up thanks again.
iF IT INTRETES YOU, i HAVE A 23 PITCH srx THATS BRAND NEW. -sCOTT
- 4790 Views
- Last post by dmottjr
Sep 29, 2011 11:55 am
- 3071 Views
- Last post by UD-T
Dec 01, 2011 12:05 am
- 74Replies
- 23824 Views
- Last post by HST4ME
Sep 04, 2012 7:42 am
- 2437 Views
Sep 29, 2011 10:17 am
- 2352 Views
Sep 30, 2011 8:02 pm
Users browsing this forum: No registered users and 52 guests
