Bilge/Well Area
Re: Bilge/Well Area
The bilge area is all cleaned up and ready for some glass work
Re: Bilge/Well Area
You can also put more then one image in a post. Save from making a bunch of posts.
Re: Bilge/Well Area
Please tell me this is NOT what you're referring to????SteveFlorioJr wrote:The bilge area is all cleaned up and ready for some glass work
Re: Bilge/Well Area
The center section looks to still be bad! But intact that is wood that I had to remove due to the soft spot on the floor. That part is tough as nails and when I tap it there is no delamination! The floor is only 1/2" plywood. Is there something that you are seeing from the pic that I am missing?
Re: Bilge/Well Area
It all looks original....it needs a core
Re: Bilge/Well Area
It is original! What do you mean core? I was going to just re-glass the bilge area and cover the foam on the left and right of the center
Re: Bilge/Well Area
Uh oh....better have a look at Nosboss rebuild thread, all that destruction is removing the core. The hull is a 3 part laminate. Glass outside, balsa, then an inner layer of glass, the balsa rots away because Hydrostream didn't seal it properly, makes the boat structurally unsound.SteveFlorioJr wrote:It is original! What do you mean core? I was going to just re-glass the bilge area and cover the foam on the left and right of the center
- 190960 Views
Mar 25, 2022 2:11 pm
- 202556 Views
- 204657 Views
- 128304 Views
May 22, 2022 8:22 am
- 87907 Views
- Last post by blowitup
May 28, 2022 10:58 pm
