Odred a new Bob's low water pick up and now looking at a jac
Re: Odred a new Bob's low water pick up and now looking at a
u can just hook up the water hose up to side of the fitting that is on the lower unit not on the low water pickup and use that for your water and plug up the holes on the factory pickups it works just fine i like taking my lower unit of perferably in the winter and just putting in garabe bag and putting in my closet lol
32:1 is too much oil for a fishing motor. You will foul plugs and end up getting carbon deposits behind the rings. Not good. Pistons swell and the rings need the groove to move into.
At 5800 rpm's, a proper oil injection is putting out 50:1. As the throttle is backed off, the oil is reduced (in an injection system).
With this information, you can adjust your pre mix oil to your running rpm's.
A race motor that turns 8500 rpm's run 32:1 due to the rpm's. A promax that turns 6700 rpm's is at 40:1.
My family run-about with a '97 175 Merc runs consistantly at 3600 rpm's. I mix my oil at 75:1 and have for the past four years with no problems. Just good FYI to know.
alaskastreamin wrote:32:1 is too much oil for a fishing motor. You will foul plugs and end up getting carbon deposits behind the rings. Not good. Pistons swell and the rings need the groove to move into.
Ya ya ya I'm doing what the eninge builder told to run it at. my Merc never see 3600 rpms with the prop slipage .the comp is the same it was 5 years ago never fouled a plug .my enigne turn 8000 rpm where the timming is set .them guys from the state of TN know there Merc 200's .got clocked at 82 mph on the river my only problem is I'm getting steering lock the speedmeter is saying 65 and now we have gps its 85 and I'm locking so 10'' setback jac and new steering set up should get to 100mph so your 50:1 I'm going to have to pass but thanks for the info .My son is looking at buying a AE21 Red white and blue That one will have a big Pabst decal .alaskastreamin wrote:32:1 is too much oil for a fishing motor. You will foul plugs and end up getting carbon deposits behind the rings. Not good. Pistons swell and the rings need the groove to move into.
- 292944 Views
Jan 29, 2021 9:17 pm
- 157208 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 263887 Views
Jun 03, 2021 11:12 pm
- 74615 Views
Feb 17, 2021 9:22 am
- 62582 Views
Mar 01, 2021 6:53 pm
