cavitation problem
Re: cavitation problem
To be honest and to keep you safe I wouldn't go up much higher. That is a light hull and with the power head so high it will not handle well and could be dangerous.
It looks like you could go up another 4-5" to where the propshaft is even with the pad. I have herd some people running 2" under but you still have a ways to get there.
I would look for a used 20" mid and driveshaft, that would work good with your jackplate. You will also need a water pressure gauge and probably a low water pickup.
77viper wrote:To be honest and to keep you safe I wouldn't go up much higher. That is a light hull and with the power head so high it will not handle well and could be dangerous.
![Agree :agree:](./images/smilies/iagree.gif)
thanks looking around for a 20 and a someone to help me install the lwp. im moving the motor up about an inch and half and am installing a hydrofoil i had laying around . hopefully this will hold me over for the next couple weeks. thanks again for everyones input and help. 65 mph for now
1975 viper in progress
It looks like in some of the pics the anti-cavitation plate is above the pad... With this set-up, that may not be the best choice. I would try lowering it. Also, what RPM are you running at that speed? It seems like you you use a bigger prop with that much power and such a light boat. I wouldn't put a hydrofoil on it.
It looks like your running a stock, small hub prop on a large gearcase. You have no chance. Your putting exhaust over the blades already, and when speed increases, the wake flattens, the prop gets closer to the surface, sucks more air, and your done. Going higher will make it worse.
You must change the prop.
![Image](http://i48.tinypic.com/34r88cg.jpg)
( Also notice where the speedo pick-up is located not a major situation but will cause problems even when set up properly )
Yep, that's not helping it either.
thanks guys , moved motor up and it was worse , got a litlle more speed with two but was real loose before i had to let off and the hydrofoil sucked *** excuse my french! going back down this weekend will let everyone know the results with this set up . thanks learning
im running a 14 1/2 24 pitch 3 / blade turbo stainless
- 112346 Views
Feb 22, 2019 11:52 am
- 240901 Views
Dec 13, 2019 7:07 pm
- 96511 Views
Feb 24, 2019 10:11 am
- 122398 Views
- Last post by CleanV-King
Dec 29, 2020 11:32 pm
- 110476 Views
- Last post by dehydrated
Mar 08, 2019 11:15 am
