Page 2 of 4
Re: New project- 89 Voyager
Posted: Oct 22, 2020 9:07 am
by alaskastreamin
Well, between building a pole barn, I get a couple hours here and there to work on the boat.
Two days ago I got the seat boxes glassed in place.
Yesterday, I got the splashwell glassed in and really went to town on the inside corners where they are prone to cracking.
I glassed the tight 90* corner first, then used structural fiberglass putty to make the new radius, then more glass. Mat and three layers of 1708
Posted: Oct 23, 2020 8:12 pm
by alaskastreamin
Today I got the micro balloon putty on and faired out.
Posted: Oct 29, 2020 11:41 am
by tnelson77
I get a kick out of seeing the fairing putty fill in where the grinding disk hit a bit deep. Mine was covered in marks like that after block sanding the primer. Looking forward to the finished results.
Posted: Nov 18, 2020 1:21 pm
by alaskastreamin
Yesterday, while letting fairing putty dry, I made a “doo-dad” for the hydraulic steering hoses. The 3” opening was just too large to have just two hoses come out.
I shaped some foam and glassed up, shaped and ready for black gelcoat.
Posted: Nov 20, 2020 5:36 pm
by alaskastreamin
Got the black gelcoat sprayed.
Posted: Nov 20, 2020 5:42 pm
by alaskastreamin
Yesterday I decided to make a swim step.
David Fatov got me measurements off his Voyager.
I leveled the hull and got my transom angle.
I am going to make fiberglass L-brackets to save some $$.
Cut a piece of foam to the shape, hot glued strips on for sides, silicone the inside corners for the radius I liked,waxed and laid up.
Got about 6 hours into this project.
Posted: Nov 21, 2020 1:58 pm
Looking great Ron! Lots of cool ideas for sure.
Posted: Nov 22, 2020 2:27 am
by alaskastreamin
Thanks Kevin!!!
Forgot to add that I filled in a 3” gauge hole and the windshield screw holes and re-gelled these areas.
The windshield will get re-mounted and laid back like the 1990 and newer Voyagers.
Posted: Nov 22, 2020 9:08 pm
by alaskastreamin
Today I took the swim step Out of the mold, did some very minor touch ups and re- shot it. I’ll pull a nice mold off this.
Posted: Nov 22, 2020 9:20 pm
by alaskastreamin
Spent 8 hours wet sanding and buffing the black on the back .
400,600,800,1000,1200 wet sand.
You can really tell when you hit 1000 grit. Starts to get a shine!!
I have a 6 step process that works great for dark colors.
The last 4 steps use a random orbit so no swirl marks show.
