New to hydrostreams
Re: New to hydrostreams
I like less, but some guys get good results with up to 5". I like the Bob's convertible plate with 2 1/2" setback.
Thats a manual jackplate correct? How would coming up on plane be with that, since with the hydraulic i was able to put the motor down to plane the boat out Im afraid it would be difficult to get the boat to go on plane.transomstand wrote:I like less, but some guys get good results with up to 5". I like the Bob's convertible plate with 2 1/2" setback.
Depends on the prop and how much load you're carrying. Hydraulic plates are heavy, getting weight off the back will help the boat plus manual plates are stiffer which helps high speed handling.
Oh i see, well thank you for the input i just looked into it and they are much cheaper than the hydraulic plates I was looking at so I think I'm just going to get one and give it a try. if i don't like it at least its not like I spent 1K on a hydraulic plate and don't like it. Thank you for the advicetransomstand wrote:Depends on the prop and how much load you're carrying. Hydraulic plates are heavy, getting weight off the back will help the boat plus manual plates are stiffer which helps high speed handling.
Oh also I forgot to ask, It says it has a 6 degree wedge, would that be beneficial to run with the wedge or would it be better to run without?transomstand wrote:Depends on the prop and how much load you're carrying. Hydraulic plates are heavy, getting weight off the back will help the boat plus manual plates are stiffer which helps high speed handling.
Might as well set it up with the extra wedge in case you need to tuck it under more.
- 17068 Views
Oct 10, 2018 4:45 pm
- 25666 Views
- Last post by msethsmile+
Oct 04, 2019 5:47 pm
- 15757 Views
Sep 11, 2018 11:27 pm
- 7221 Views
Sep 09, 2018 5:38 pm
- 8289 Views
Dec 01, 2018 12:25 pm
