still overheating
Re: still overheating
the water pickup seal worked. i now have 10-11 psi at idle. it drops to 7 as i rev it. not sure why? ive ordered a whole waterpump assemebly. might as well start with all new parts. ill have to weight till saturday for a test run, it gets dark at 6:00 when i get out of work. thanks for all the help and suport, mike
The poppet valve opens at about 1800 rpm, should drop the pressure about 10 psi
im not sure what a poppet valve is, what it looks like, or where it is. when it drops the pressure about 10 psi, does that mean it regulates the pressuer at constant 10 psi, or does it drop it 10 psi from where it is at 1800 rpm? does the pressuer change with rpm? what pressuer should i have while runninig? i dont know if it makes a differance, but here in florida most of us dont run t-stats.transomstand wrote:The poppet valve opens at about 1800 rpm, should drop the pressure about 10 psi
tx mike
When your running the lwp also forces water to the engine.
It drops it about 10 psi, to prevent excess pressure at high rpm. Thermostats regulate pressure in a stock motor, and should never be removed. Having no thermostats makes it extremely difficult to keep the block full.fla.viper wrote: im not sure what a poppet valve is, what it looks like, or where it is. when it drops the pressure about 10 psi, does that mean it regulates the pressuer at constant 10 psi, or does it drop it 10 psi from where it is at 1800 rpm? does the pressuer change with rpm? what pressuer should i have while runninig? i dont know if it makes a differance, but here in florida most of us dont run t-stats.
tx mike
- 26830 Views
- Last post by HydroAng
Aug 04, 2020 9:59 pm
- 6185 Views
- Last post by mtkst19
Oct 26, 2014 10:38 pm
- 11837 Views
- Last post by Fairwindracing
Nov 15, 2014 6:57 pm
Vegas - Fully Restored to Mint Condition - For Sale
Last post by Nueces Bay Rat « Oct 19, 2014 4:18 pm - 4Replies
- 17121 Views
Jul 10, 2020 6:04 am
- 19Replies
- 16258 Views
- Last post by canuckr
Jun 29, 2015 8:32 pm
