Glad Chet's ok!
Oakhill
Re: Glad Chet's ok!
Post: # 16023Post Oakhill »
Oh no!!!!! but great you are ok man!!!!!
Varigeo
Re: Glad Chet's ok!
Post: # 16024Post Varigeo »
Glad youre ok!! I saw the pics and was at a loss for words. Sorry about the boat. But as said 1000 times Im sure you can build another. Life is sweet and short god speed to you. Hope youre not hurting too much
Has thanked: 365 times
Re: Glad Chet's ok!
Post: # 16026Post Hippie459MN »
Little video of a pass from earlier that day...
[youtube]http://www.youtube.com/watch?v=wTgowt6qT14[/youtube]
These are some pics he took today as well...
Looks like that core and transom job held up good though. Cant wait to see what the next project will be. Please say another stream!!! And I will be more then happy to give a lending hand in whatever it may be. :up:
Re: Glad Chet's ok!
Post: # 16029Post Hippie459MN »
Sorry, I just had to post this too... Having never seen the boat personally when it was completed (Only pictures), I can say I personally seen much of the work that went into this boat...
Only thing to do next is something better. :up:
[youtube]http://www.youtube.com/watch?v=3IuuLc-D_20[/youtube]
:vking:
bhbestcustoms
Has thanked: 7 times
Re: Glad Chet's ok!
Post: # 16032Post bhbestcustoms »
Wow!! Thats insane!! My farther and I and even my family are very glad you are okay! Its a shame it happened but your still here to build a better one! Cant wait to see you on your next project!!! :up: :boating:
Hydrostream Owner,
Bradley Harris
Bhbestcustoms
varmint1
Re: Glad Chet's ok!
Post: # 16036Post varmint1 »
Chet I'm glad your ok and doin well after the incident, I really hate that it happened and I'm speechless about the Viking. Hope your mom is doing well also our prayers are with y'all
Surface Scratcher
Re: Glad Chet's ok!
Post: # 16063Post Surface Scratcher »
Yes, glad you're OK. The loss of the boat will hurt longer than the ribs will. It's really just so unfortunate. :(
Re: Glad Chet's ok!
Post: # 16073Post 77viper »
Thanks guys, I can say it was completely my fault for pushing it to hard to soon. I have been so busy that I didn't get the seat time I needed to feel what the boat wanted and was going to do. The first time going full throttle was at Three lakes when the picture of the boat completely out of the water at close to 100, that should have had me more concerned than it did. I didn't use it until the night before I went to Iowa to race and after 20 minutes of running the pin came out of the clutch dog in the gear case and stuck it in forward but I took it and raced it anyway, another bad decision. At the end of the 1/4 on the last race the gearcase went into reverse and twisted the drive shaft and propshaft as well as tore up everything inside the case so I couldn't drive it for a week and a half while I had a driveshaft shortened. Anyway I might have had 4 hours of run time in the boat when it went over.
The boat would lean to the right at about 100 then straighten up from the beginning and I was trying to figure out why and correct it. I was raising the motor as I had had it 1/8" below the pad from break in. As I was going up the lean was still happening but at a higher speed. This last time out it leaned at 107 away from the landing but I stopped at that speed. On the way back I decided to see if it would come out of it and as is straightened up it lifted off the water just long enough to realize I was airborne then it went over violently. It did a complete flip in the air and as the bow came down it hit the water throwing me out and tearing off the bow, the water pressure went through the boat blowing it apart. Somehow the thing was upright and floating about 50 feet from where I stopped.
I am planning on doing another one like it but with a shorter dash, that's one thing I didn't think looked right. There are a couple options but I'm going to wait a bit on starting it. There might be something else in the works as well as there are some boats in the club that are a lot faster than what a vking can do safely.
Rut311969
Re: Glad Chet's ok!
Post: # 16076Post Rut311969 »
Well glad to here your doing good and still in good spirits.
fla.viper
Re: Glad Chet's ok!
Post: # 16103Post fla.viper »
glad ur ok! after walking away from that whats next.......... walking 0n water?
