Water Pressure?
Water Pressure?
Just purchased Vector with 200hp mercury and water pressure with muffs on at idle 0-1psi(water comes out of exhaust and 3/8 line off of head),3000rpm 3-5psi.So i thought impeller was junk,replaced impeller,gaskets,housing,plate.Same results.Any ideas???
Re: Water Pressure?
If you sucked sand or debris into your motor it can clog the tube going to your gauge. I just had it happen to me, and I had to clear that line. I'd check that first, before I got crazy with anything else. It could have happened before you bought it. If it has a low water pickup, sometimes the muff doesn't feed properly and you have to submerge it in a big trough or go directly into the intake tube on the lower unit.
Re: Water Pressure?
It's hard to get a good reading running on a hose. In the water 3-5 is good at idle up to 20 at 5000. Some gauges aren't the most accurate either.
Re: Water Pressure?
I was thinking the same,will find this weekend as long as it does not RAIN again lol
Re: Water Pressure?
I hear ya, I finally grabbed my viper from storage and it's rained or been too windy every day.
Re: Water Pressure?
Even if the gauge is good, if the tube coming off the motor is clogged with sand or debris, you won't get a good reading. On the hose, even at idle, I get at least 15-20lbs. of pressure. In the water, at idle, 3lbs. or less. At running speed, I get 30-35lbs.
Re: Water Pressure?
I'm with 77Viper on the hose reading. It is hard to get a good reading off the hose aswell as the muff kits aren't overly reliable as for solid pressure. I have three muff kits and 2 of them read low and the other reads higher then the others.
1979 J-Craft Pro Ski SOLD
- 131347 Views
Mar 10, 2022 10:00 pm
- 157714 Views
Mar 10, 2022 10:03 pm
- 190940 Views
Mar 25, 2022 2:11 pm
- 202522 Views
- 204638 Views
