Hippie459MN wrote:Heat maybe. I will take a look at my frame later today when I get home and see what it looks like.
[ Post made via Mobile Device ] ![Image](http://www.hydrostreamforums.com/images/mobile.png)
Be carefull heating aluminum, it can easily be burned out. If there is steel inside the rail more heat will be needed to bend and may take more than the aluminum can handle. I don't think the rail has any other material other than extruded aluminum in it and in the extrusion process the aluminum will become harder loosing is ductile properties. aluminum doesn't like to be bent and then bent back it will tend to crack at any extream bend.
My rail has a bow in one side also . I will like to know how yours comes out.
