76 vector restore
kytekeith
Re: 76 vector restore
Post: # 2879Post kytekeith »
You guys keep in mind that my pricing is only from one supplier , i remember seeing balsa for 13 bucks a 2x4 sheet which is 7 bucks cheaper per sheet then easterns price. also it may take thiner or thicker stocks to give the same striengh as 1/2 inch balsa. I will post comparison to duplicate 1/2 inch balsa as soon as i have all info available.
LSaupe
Post: # 2880Post LSaupe »
Here is a good link to the article previously mentioned.
http://www.compositesworld.com/articles/getting-to-the-core-of-composite-laminates.aspx
Original link in the post had the word article misspelled.
Post: # 2881Post VultureNo2 »
Thanks - Great article.
kytekeith
Post: # 2884Post kytekeith »
LSaupe wrote:Here is a good link to the article previously mentioned.
sorry guys my bad
kytekeith
Post: # 2906Post kytekeith »
After spending hours and hours on reading alot of stuff on composite cores i am gonna take a break and actualy do some work on the vector. I bought a resparator and tyvek suit and ready to grind. I am gonna cut out a previous patch job. Image
It looks like the core was gone when this repair was done. Someone just stuffed the hole with cloth and resin filling the missing core void. Image
From the bottom it looked like someone had rubbed the coat off from beaching it and painted over
kytekeith
Post: # 2915Post kytekeith »
I think the bad spot was cut out then filled from the outside with alot of resin and a little glass. Maybe a couple layers of glass can reinforce the patch.?
Post: # 2919Post 77viper »
I had a spot like that in about the same spot. I ground it smooth on the inside and added 3 layers of mat to the inside. Then 2 more under my core. I then was able to just smooth the outside out with some dura tec p14 I think it was. Anyway it's a filler for below the water line.
I'm shure there is a better way to fix it but that's how I did it. :up:
kytekeith
Post: # 2932Post kytekeith »
The outside is smooth and cannot tell it has ben patched except ror the paint. I dont plan on a full paint or gel because it looks fairly good now so i am hoping just a couple layers of glass inside will do.
kytekeith
Post: # 2934Post kytekeith »
I have been reading alot of articles written by a marine surveyor that is against core construction in hulls. His name is David Pescoe.
http://www.yachtsurvey.com/ATC_Core-Cell.
Check out some of the stuff in (core and structural issues) but don't stop there.
LSaupe
Post: # 2935Post LSaupe »
If it doesnt go, add the "htm" to the end.
http://www.yachtsurvey.com/ATC_Core-Cell.htm
  • 1988 v king
    Last post by billyho « Sep 23, 2009 3:08 am
    1Replies
  • pic
    Last post by billyho « Sep 23, 2009 3:10 am
    27Replies
    Last post by jlw7
    Jul 12, 2010 12:44 pm
  • v king
    Last post by billyho « Sep 23, 2009 8:22 am
    2Replies
    Last post by JUPITER VALERO
    Oct 03, 2009 1:00 pm
  • pics
    Last post by tommy « Sep 23, 2009 11:35 am
    14Replies
    Last post by zizziz
    Apr 06, 2014 10:23 pm
  • OMG! I'M IN LOVE!
    Last post by Vegas XT « Sep 25, 2009 11:25 pm
    5Replies
    Last post by ccrick
    Sep 26, 2009 10:26 pm
