Bought a boat that was supposed to be turn key. Well it wasn't, floor and stringers are rotten... Motor problems and more since buying it.
There is 20% moisture at the transoms in some areas, does that mean it needs to be replaced as well?
Thanks Mark in Kingston On.
88 hydrostream vission with a 150 Merc.
well here we are
Re: well here we are
Dont forget about the core also.
Read here if you're not familiar with it - https://www.hydrostreamforums.com/the-core-what-is-it-and-where-it-is
The add pictures button seem to work here. What is the exact problem you are having?
Yep had not forgotten about it. Seems solid, but was going to drill a couple spots near the back to see if it's pooched, not sure if there is a better way to go about it.
Any advice would be appreciated.
98% of the time, if the floor and stringers are rotten, so is the core. Sadly... We've all been down the core job road before so I feel your pain. Good news is, once you fix it right, it will probably outlast you.
Hydrostreams used a proprietary rub rail and was made in house so you will not find original rub rail.
- 14643 Views
Jul 24, 2017 12:03 pm
- 8717 Views
Jul 26, 2017 7:45 pm
- 9846 Views
Jul 26, 2017 3:12 pm
- 15516 Views
Sep 03, 2017 7:26 pm
- 12468 Views
Mar 09, 2018 7:06 pm
