79 Vulture Recore
ccrick
Post: # 2447Post ccrick »
Bill, first of all, pm me your e-mail address and I have a few pdf files on a v king resto Ill send. A lot of good info and will help you understand more. The pad is kinda like the keel. The center of the bottom of the boat thats flat 2/3 of the boat. At speed, the whole boat rides on it. When I took it off the trailer, I set the pad of the boat on a 2 by 8 reinforced with 2 by 4's on either side to keep the plank straight so when the boat was on it, the pad would not distort. Then I blocked the boat at the chines. (were the bottom meets the sides of the boat). The core lays pretty flat in most of the boat. Yours is just a streched out v king. Get me your e mail and read. It's not really that hard.
The pic shows the layout of the core for the v king. I'm pretty sure it would be the same. Hippie would know. This shows it bonded to the hull but not laminated over with glass yet.
Post: # 2448Post Hippie459MN »
ccrick wrote:Bill, first of all, pm me your e-mail address and I have a few pdf files on a v king resto Ill send. A lot of good info and will help you understand more. The pad is kinda like the keel. The center of the bottom of the boat thats flat 2/3 of the boat. At speed, the whole boat rides on it. When I took it off the trailer, I set the pad of the boat on a 2 by 8 reinforced with 2 by 4's on either side to keep the plank straight so when the boat was on it, the pad would not distort. Then I blocked the boat at the chines. (were the bottom meets the sides of the boat). The core lays pretty flat in most of the boat. Yours is just a streched out v king. Get me your e mail and read. It's not really that hard.
I wouldnt mind having this also. PM sent. :up:
ccrick
Post: # 2449Post ccrick »
sent :up:
Post: # 2450Post Hippie459MN »
Got it. :D Some reason part 2c is corrupt here. :( The other 3 are fine though. Excellent reading for sure. This something you found or is it yours?
Post: # 2451Post Hippie459MN »
ccrick wrote:The pic shows the layout of the core for the v king. I'm pretty sure it would be the same. Hippie would know.
Yes, The Vulture is identical to a v-king but 2 feet longer. :up:
http://www.hydrostreamforums.com/vulture
:boating:
Post: # 2452Post VultureNo2 »
Happy Thanksgiving and really appreciate the pictures and advice.
Rick, here is my e-mail address
bdonahoe400@wi.rr.com
Feel free to e-mail me anytime. I haven't had a chance to take a close look at all the picture send and finish reading the thread, but did take a long look at hippies thread.
I'm cooking today. Nice enough here to consider going for a boatride.
Will head north to the lake tomorrow.
Bill
ccrick
Post: # 2453Post ccrick »
Hippie459MN wrote:Got it. :D Some reason part 2c is corrupt here. :( The other 3 are fine though. Excellent reading for sure. This something you found or is it yours?
I found it in the hydrostream registry I'll resend 2c
Post: # 2462Post VultureNo2 »
Rick - The picture of your core in but not glassed over really helps. Questions. Are those the original stringers? is the core on the left and right different that what's in the middle underneath the stringers? Are those the new stringers already glassed back in on top of core that is the same foam as on the sides? Also, I see the lines in the foam. It is foam right? Are those all separate strips of foam or one solid piece? Did you start with a large sheet of foam and cut it, or was it already in smaller strips? The stuff I was looking at was 4 feet by 4 feet. Just cut it even and but it up against the next piece? Thanks for the advise on setting the boat of the trailer. Are you saying a 2x8 flat on the ground and 2x4's standing upright screwed to the 2x8 as the base? Bill
Post: # 2463Post VultureNo2 »
Hippie great thread from screamandfly. Thanks. I will move my tread to WIP tomorrow as time permits. Bill
Post: # 2466Post Hippie459MN »
ccrick, Got ti and works perfect. Excellent read for sure. Cant believe I missed that over at .org
Bill, No problem. That thread along with 77Vipers here is going to help me out alot. Among other threads as well.
If you would like I can move this topic to the WIP section if you like unless you want to start a whole now topic there. :D
Cant wait to see lots of pictures of your Vulture. :up:
