Drain plug help
Drain plug help
I'm getting ready to glass in the stringers Balsa in my Vector and started thinking about the drain plug hole. Is there a block of wood that goes on the inside of the hull at the drain plug? I can't find any pictures of how it's supposed to be . I figure I better find out before I started glassing everything in, I would hate to mess it up now.
Re: Drain plug help
yess theres a block of wood buy a new drain hole plug usually brass put it thru hole then measure the length sticking out on the inside make a piece to fit were plug is slightly outsude if block ill look for a pick from my restore
Re: Drain plug help
- Screenshot_2014-07-30-03-06-27.png (821.09 KiB) Viewed 7162 times
Re: Drain plug help
When you put the brass sleeve in did you put resin in the hole or did you seal the sleeve with 5200?
Re: Drain plug help
5200 and the sleeve requires a crimping tool
http://www.jamestowndistributors.com/userportal/document.do?docId=1022
Re: Drain plug help
I just resined mine in and made the hole in wood were plug had to be tapped in transomstands way is great also goodluck
Re: Drain plug help
only thing about using 5200 is that if the bilge ever gets soaked with some gas it can softer, or weake the 5200, and, some metals don't bond worth a darn to 5200. best thing to do is oversize the hole by about 3 sizes, wet it out with epoxy until the wood won't soak anymore, then back-fill with thickened epoxy (silica, or microfiber), let it harden, redrill and place the tube in with more thickened epoxy.
Re: Drain plug help
After redrilling the resin filled hole do I add wet resin then install the brass sleeve ? Do I crimp the sleeve while the resin is still wet?
Re: Drain plug help
yeah, wet it out, both the hole and the brass, after you scratch it with some 60 grit or so, and put some slightly thickened (ketchup consistency) resin on the brass, and then do your crimp to instll.
Re: Drain plug help
Thanks. I got the stringers in, do I need to put a hole at the rear of them to let water drain from the sides in the box at the drain plug area?
- 1172 Views
- Last post by ccrick
Aug 06, 2009 7:23 pm
- 16Replies
- 4887 Views
- Last post by vector62
Jan 05, 2010 7:27 pm
- 14046 Views
Aug 17, 2009 8:03 pm
- 3741 Views
- Last post by Maple Leaf
Aug 13, 2009 2:14 pm
- 4610 Views
- Last post by tommy
Aug 14, 2009 9:07 pm
