that plate is super simple. it has one 1/8 " plate on trans that acts as a slide. the outer plate is 1/2" maybe 5/8". has 4 slots for the trans bolts to run through... one fir the splashwell drain. the motor mount bolts are counter sunk.
that ride guide system is like butter!
it came with original steering wheel and an external mounted speedo.... pretty cool stuff.
he's gonna rig it with a heavily modded carb 200. hopefully making 240ish hp
81 vector....complete restore....1991 7 pedal 200 slightly modded ALWAYS under construction
Sory noob here, what's the difference between comp vking and vking?! I'am from Canada and have seing the difference between Canadian vking edition and us version. Other then floorless and can't tell thé difference for the term 'comp'
